Keeping Your Nuts On
11 replies to this topic
#1 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 11 August 2009 - 06:25 AM
i noticed when i began this rebuild that the nuts and bolts on the exhaust mani were very loose. some were scarcely finger tight and the DP had to be tightened a couple times. what are you using to prevent this? will lock washers do anything for me?
1996 855R
#2 Johann
  • 4,979 posts
Posted 11 August 2009 - 07:30 AM
Make sure the studs are secured in the block. After that the nuts can go on together with the OEM thick washers and the nuts need to be torqued down to factory spec which is only 25Nm. Best would be to tighten them clockwise from the middle to the outside. There is one smaller hole in the manifold in the middle where you can start.
#3 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 11 August 2009 - 04:07 PM
If you are that worried safety wire them
#4 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 11 August 2009 - 04:40 PM
well for them to have worked themselves that loose on a stock engine i am a bit worried. maybe just never torqued right the first time but damn
1996 855R
#5 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Posted 11 August 2009 - 04:43 PM
Once they rust on their good. You can use a jam nut or wire them in the mean time. Mine are wired and have never had an issue.
#6 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 11 August 2009 - 04:46 PM
quick rundown on safety wire por favor?
1996 855R
#7 FCP Groton
FCP Groton
  • 1,838 posts
Posted 11 August 2009 - 04:49 PM
This post makes me want to check my exhaust nuts. I never thought they could come that loose.
Andrew Owendoff
#8 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
http://volvospeed.co...afety_wire.html
And a practical application:
#9 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 11 August 2009 - 04:52 PM
i love volvospeed
1996 855R
#10 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,209 posts
Downpipe ones back off all the time. Service manual even says to check them. Manifold ones do not have this problem except when new. Once they rust on you are good to go
#11 PsychoWagon
PsychoWagon
  • 831 posts
Posted 12 August 2009 - 01:53 AM
Quote
lol, or torque them when the engine is steaming hot, then you won't have an issue :)
1998 S70 Automagik - M56 Swap - RSI Rods - OS2 Pistons - 440cc injectors - 19T Hybrid - 21psi after engine break in
FOR SALE: Automatic Transmission 94-98 850/X70 - 260000km 3 synthetic flushes
98 T5 Engine - 265000km 155psi across board
#12 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,479 posts
  • Gender:Not Telling
Posted 12 August 2009 - 02:15 AM
I know of another way to keep nuts on, it is much faster and easier. The method might be slightly offensive to some religions though. :o :P
98 S70 T5M
