Still Not Running
Posted 18 August 2009 - 11:21 AM
I checked the oil after the few minutes I could get it to run and found tiny air bubbles on the dipstick. I realize that there are a lot of things that can cause bubbling in the oil from bad crankcase ventilation and poor pickup seals to a blown headgasket or cracked block. I let everything cool down for an hour or so and rechecked the oil. No bubbles, but when I pulled the filler cap off and shined a flashlight down into the top of the head, I noticed a slightly greenish tint in the oil. Could be coolant, or just the reflection from my flashlight.
I also noticed when I changed the plugs that on cylinder 2 (or 4, it was second from the left), the embossing read "B3340 1.1". The injectors were a dark red color as opposed to the bright oranges that were included with my original engine (from the PO who had installed 350cc whites). Also, the '97s use a fuel return line next to the main fuel line. To my knowledge, the stock fuel pressure regulator should have a nipple on it that allows a hose to be run from the FPR to the return line. The fuel rail that was on my new engine (that had 63K miles on it) was completely sealed and did not have any way to reroute fuel to the return line. As much as I'd like to believe the shop who installed my engine got the right engine, I'm questioning whether or not they did. My first motor had "B5234" on the head under the cam cover. I don't know whether or not it had the "T" embossed, but it was a stock '97 850 R engine.
I checked the coolant tank and found no traces of engine oil; however I'm not ruling out a blown headgasket. I would change the oil, but even if there was coolant in the oil (without a blown HG), there's no reason it should cause it to barely idle with virtually no vacuum.
So, if anyone could give me some more pointers, I'd appreciate it. I'd also like to know what the B3340 1.1 is all about, as well as the different fuel rail and injectors.
Posted 18 August 2009 - 04:00 PM
No cures here but some thoughts...
If you only have 5psi vacuum you ought to have a leak in the "system" somewhere. How about the TB? Is the plate closing?
On the idle, it sounds like a fuel or air problem but the crappy idle could be causing or at least negatively impacting the vac issue. What about the IAC? Clean that lately? Are air connections really tight? Is IAC running? What about the fuel filter...is it in good condition? Injectors clean?
Posted 18 August 2009 - 06:27 PM
Posted 18 August 2009 - 07:30 PM
I wouldn't worry about the green color when you looked under the cap. If coolant was in there, it definately wouldn't be green.
I guess I don't have the back story. A shop replaced your engine?
Posted 18 August 2009 - 09:53 PM
Yes. My HG blew in about 20 places and oil filled the coolant. Since I had previously had a very small coolant leak in the radiator, I was an idiot and used some stop leak in coolant. I learned my lesson on that. But anyway, the stop leak dyed the coolant brown so I didn't know when there was oil in the coolant. The head was off by .015" and the coolant lines through the block were completely sludged up and couldn't be cleared out, so only replacing the head wasn't an option.
I did some more research on oil in coolant and coolant in oil and saw some pictures. Definitely isn't coolant in the oil. The bubbly mixture I saw still looked like oil, not like a foamy chocolate milkshake. Plus, there's no oil in the coolant, so for now I'm ruling out a blown HG. I do have a coolant leak, but it's from where I replaced the upper heater hose and it didn't seal up too well in the firewall, which is another problem in and of itself, but it's taking a backseat for now.
There WAS water in the tank, and a fair amount. When I drained the tank, I hooked my old fuel filter up to the line, then clamped a siphoning hose to the front of the filter and ran it into a gas can. Once I could no longer get anymore fluids out, I unhooked the filter and drained it. Probably got a half cup of water out. Then I mounted a catch can under the fuel hose and pumped another cup or so out murky brown water out. It didn't fix the problem, but at least I was able to eliminate the water in the tank as the cause of the problem.
The injectors are clean (350cc whites), the IAC is cleaned out, and all the IAC hosing seems to be in good shape.
When the car was idling and I was poking around under the hood, I did hear a low pitched whistling sound coming from somewhere near the vacuum tree/intake manifold. So even though all the vacuum hoses seemed fine, I'm suspecting a vacuum leak, and a pretty serious one. I've had bad hoses that brought vacuum down to 12-14 inches at idle, but nothing that pulled it down to 3-5 inches. I'm suspecting either the vacuum tree itself is cracked, has a bad seal on the intake manifold, or that the intake manifold is cracked, loose, or has a bad gasket attaching it to the head.
I talked to my mechanic in Louisville and he told me to try a few things to eliminate air delivery and fuel delivery. For air deliver, unhook the MAF. If it idles in a closed system, it's the MAF. As soon as I unhooked it and started the engine, it died. Then he recommended spraying ether into the intake manifold to see if it ran okay with direct injection. It didn't, so I ruled out a bad fuel delivery, but I still wanted to clear the water from the tank.
When I started the car, it revs up to 1300rpms or so and gets a full 20-21 inches of vacuum. Within a few seconds, the rpms drop to 600-700 and the vacuum pulls back to 3-5psi and holds there as it gets an extremely rough idle and finally dies in a couple of minutes. Like I said, I can hear a very muted, low pitched hissing sound at the TB area of the intake manifold, so I'm gonna pull everything out there and check it. If it ends up being a cracked manifold, no biggie. I still have the ported manifold from my first engine I can install. I'm gonna go out and get started and post up later, hopefully with some good results. It is possible the IAC isn't working, and if that's the case, well then I think that would be the problem. When I took it out it wasn't dirty and there were no hangups, but then again, it might not be working. I have no idea how to check its functionality though.
Posted 18 August 2009 - 10:38 PM
Maybe the TB isn't bolted down to the manifold tight?
Dig around in there and let us know.
Posted 19 August 2009 - 01:15 AM
Is it possible to check the IAC's functionality? I've tried running my car the way it is without the IAC hooked up and it died instantly. I'm wondering if the IAC isn't working, even though the inside piece swivels like normal.
Posted 19 August 2009 - 05:22 PM
blown_volvo850r, on 19 August 2009 - 01:15 AM, said:
Posted 19 August 2009 - 05:52 PM
Posted 19 August 2009 - 06:05 PM
OrEo931, on 18 August 2009 - 06:22 PM, said:
+1
Same way my car will run if one of the hoses are off. Check intake hose at turbo too.
Posted 19 August 2009 - 10:12 PM
I noticed when the car is idling a lot of noise is coming from the IAC, if that means anything. More to come later.
Posted 21 August 2009 - 05:52 PM
Now, here's the weird part. I unhooked the IAC and started the car. It still had a rough idle, but the boost gauge was reading 18-19 inches of vacuum, and it held there until I reconnected it. As soon as I hooked it back up, the vacuum went back down to 4-6 inches. After several restarts to get the engine to operating temperature, unhooking IAC would cause the motor to stall. Hooking it back up would still read very low vacuum and it would keep the rough idle for a minute or two, then stall.
Any conclusions from that?
#14
Posted 25 August 2009 - 10:57 PM
P0141 - O2 sensor heater circuit malfunction (bank 1 sensor 1)
P0137 - O2 sensor low volts (bank 1 sensor 2)
P0131 - ???
P0303 - Cylinder 3 misfire
P0301 - Cylinder 1 misfire
P0300 - Multiple/random misfires
P0304 - Cylinder 4 misfire
P0305 - Cylinder 5 misfire
P0302 - Cylinder 2 misfire
P1507 - ???
P1505 - ???
P0336 - Crankshaft position sensor A CKT range/perf
This problem got worse with rain, and an enormous storm with several puddles driven through ended the R's ability to run. When I was under the front end securing the downpipe to the turbo, I noticed a complete sh*t job on the wires going to the front O2 sensor. We're talking wires hanging around with a couple spots of duct tape here and there. I'm wondering if some water got up in there and shorted something out. I'm also concerned about the crankshaft position sensor, although I'm not exactly sure what that code means. If anyone could explain the codes as well as define the three 1-x-x-x codes, I'd appreciate it.
#15
Posted 26 August 2009 - 08:05 PM
P1507 2-4-5 Idle air control (IAC) valve signal closing Low
P0131 2-1-2 Front heated oxygen sensor (HO2S), signal Low
