got a kind of a stupid question.. i popped off the caps where switches are supposed to be around my steering wheel and the shifter and i've noticed almost every one of them had a harness behind them.. is it possible to install the heated switches and other switches in there?
Switches!
Started by 95850turbo, Aug 23 2009 05:14 PM
Posted 23 August 2009 - 05:14 PM
Posted 23 August 2009 - 05:43 PM
what kind of a car do you have?
i know 850 and x70 have most of the harness installed
depending on what accessory you want; it might need additional work other then switches to make it work
K.I.S.S. - Keep It Simple Stupid
'97 854 GLT | 16T | ARD Green | OBX full exhaust | R Mani | NA TB | Unorthodox Racing Underdrive Pulley | etc...
Posted 23 August 2009 - 08:27 PM
for the heated seats youd need to put the heated pads in the seats and wire those up i believe
so its more then just the switch...
(i might be able to get all the peices at my JY if you want to try)
00 Olive V70R -- 98 S70 T5M -- 99 Silver V70R - FOR SALE! - CLICK!
Posted 25 August 2009 - 07:46 PM
Confirmed. Sadly, you can't just hook up a switch and have heated seats. However, depending on your car the wiring may be factory installed, making your life a lot easier if you really do want to install these options yourself.
2007 Volvo XC70 Daily Driver Steel Cargo Barrier (+50HP), Cargo Cover (+30HP), Bluetooth (+5HP), iPod Dock (To Be Installed, +15HP)
1995 Volvo 850 T-5R Currently in Storage RWD Conversion, 8-Speed Automatic Conversion, Quadruple Turbo w/ Supercharger and NOx
