Timing Belt Turned Ugly
10 replies to this topic
#1 JC 855 GLT-R
JC 855 GLT-R
  • 5,404 posts
Posted 25 August 2009 - 04:27 PM
went to do preventative work on my dads 90 740 gle. car sat for a week waiting on the belt. got all the marks lined up and put the new belts on and lined up, cranked the motor a few times by hand and the motor and something kept hitting something. so first thought timing jumped or something and pistons hitting valves etc, i tdc 'd the motor and tried again no avail. so i thought it was unrelated and the torque converter bolts loosened and was hitting the block but that wasnt it. then we took the cams off and the cam carrier and the works, all the valves were closed spun the crank by hand and pistons are still hitting. mind you that all the plugs are also out of the car. spun the motor every which way and theres enough resistance to loosen the crank bolt. so next step is to take the head off which we did and no bent valves or obvious marks noting that the pistons and the valves collided. what i did find is that there was a 2 millimeters thick of carbon built up on the edge of the top of the cylinder, which was causing it to get stuck. after ripping the head out the carbon came out and the head was bolted back on hand tight and the crank was spun and it was free and nothing binding. carbon build up caused the piston to stop shy of tdc??
1993 Mercedes-Benz 190e 2.3 91k still broken
1996 Volvo 855 GLT-R 320+k and going ( Project GLT-R)
1998 Subaru Outback SUS -Daily Driver
Volvo for LIFE......
Parts for sale
#2 Hanks
Hanks
  • 3,496 posts
Posted 25 August 2009 - 04:39 PM
its a redblock engine? its a non impact engine. pistons cant hit the valves.
-Kevin-
2004 V70R: 3 angle valve job, Phuzzy FMIC, IPD Neutral rear sway
White '96 850 T5M:Black '94 850 T5
Volvospeed Useful Threads For Repairs
VS Docs now live
#3 JC 855 GLT-R
JC 855 GLT-R
  • 5,404 posts
Posted 25 August 2009 - 04:41 PM
its a red block b234f DOHC motor. pistons can hit valves...
Parts for sale
#4 mdlimy
mdlimy
  • 3,380 posts
Posted 25 August 2009 - 04:46 PM
+1 gle is dohc, mmmmmm i love that motor.
but damn thats alot of carbon build up, what condition were the cylinder walls in?
#5 JC 855 GLT-R
JC 855 GLT-R
  • 5,404 posts
Posted 25 August 2009 - 04:53 PM
walls have the usual wear and tear for a motor with 180k car has 280k on its 4th motor.
Parts for sale
#6 TyConn
TyConn
    Delta Bravo
  • 1,045 posts
Posted 04 October 2009 - 04:35 PM
are you high??????
even SOHC have interfering heads
1998 V70 T5 M - FOR SALE, PM ME!
1994 854M Silver on Black
1998 Black on Black S70T5
1998 S70 GLT
1990 245 DL M47
...RIP at 320K
#7 Dave 54
Dave 54
    Old Man Crew Pledge
  • 4,905 posts
Posted 04 October 2009 - 05:12 PM
are you high??????
Wrong,there non interferring, my belt snapped going 40mph, no damage, put new belt on and purrs like a kitten.
DAVE
96' 850R
#8 JC 855 GLT-R
JC 855 GLT-R
  • 5,404 posts
Posted 04 October 2009 - 06:55 PM
+1 i had a 87 gle that the belt went on and a 760 T it went on and the motor was fine with a new belt. i think the b234f's were the first for the interference motors..
Parts for sale
#9 Yellow95
Yellow95
    Grandpa G
  • 6,746 posts
Posted 05 October 2009 - 10:47 PM
Put an IPD cam in there nd it will become an interference motor.
Gary
#10 Ipd
Ipd
    Mr. IPD
  • Validating
  • 1,562 posts
Posted 05 October 2009 - 11:04 PM
Yup, even some stock ground cams made 8 valve motors interference.
#11 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,761 posts
Posted 08 October 2009 - 12:10 AM
That would be new to me but suppose anything is possible>
"SMOKE TROUT NOT CRACK"
