Yep tough one i know
Eurospec 850 Turbo/R Manual Ecu
Started by oRange855, Sep 06 2009 12:17 AM
Posted 06 September 2009 - 12:17 AM
1996 855 T-5M: 18T, R Mani, Simmons Exhaust, Whites, projectors, IPD Stage 3 Tune T-5R/V70R hybrid interior
1984 242 GLT- The money pit 15K+ invested
1980 242 GT-LH 2.2'd
Posted 06 September 2009 - 01:06 AM
Easy. Send me either an 072 or 628 ecu and I can program euro maps.
Be advised no OBDII in euro maps...
Posted 06 September 2009 - 01:18 AM
Hmm, pm sent
Posted 06 September 2009 - 07:08 PM
A Friend and I are running Lucky's/IPD's Euro manual map. It's awesome . Much smoother idle and off the line. And the boost builds up very linear no spikes.
And the non obd2 is a minor issue if you have done stage 0. You can simply make a led-obd1 push button switch like the 94/94 diagnostic box under the hood. They are super easy to make and cost less than 5$ to make.
96 850 (412) wagon W/2 racing seats no rear seats, ..Converted to M56h with Quaife. R clutch,Kw v2 coilovers, qbm end links,Ipd sways,strut and shock braces/ Front/rear lower Ultra racing chassis braces. Team Dynamic 17in rims 17lbs .Poly mounts on trans, engine and firewall.Porsche Bbk, Ss lines, Super Blue Ate.5mm Spacers,Rolled Fenders,R Manifold, T04E 50 trim @18psi. Divorced WG and BOV ,3in Downpipe, gutted 3in cat,2.5 tme/Ipd catback Gizzmo Ebc, 1 gallon Aem progressive Meth Injection kit. Walbro 255. Na mani W /960 plate and Na Silicone Tb hose. Boost/egr/wideband gauges dash mounted. Double Din touchscreen Nav. 12in Fosgate p3 and 2 Alpine amps/ + Cf spoiler+ V70 stuff.
