Alternator Questions
4 replies to this topic
#1 ceesenacho
ceesenacho
  • 15 posts
Posted 10 September 2009 - 08:19 PM
ok so her'es my problem,
about a week ago i started started hearing a clunk/crunch from the passenger side, it looks like the cv joint/axle needs to be replaced the boots are trash and the grease has spun out so instead of fixing the boots i opted to replace the whole unit i got from fcp...its in the living room nw waiting to go in tomorrow. along the way i started to hear an increasingly louder, (over about 2 weeks)hum/whirling noise. the guy at autozone hooked something (battery cables?)to the battery and pressed a button, the alternator clicked a sounded as if it was winding down...he said the alternator is on its way out. so as anal as i am i had to do some more research. i came across a test to see if it was bad...i started the car, removed the pos and neg terminals...it kept running indicating the alternator was fine. im so confused.
#2 DHV70
DHV70
    Deadbeat, owes people money Derrick Hendrickson 860-841-0504
  • 576 posts
  • Interests:Derrick Hendrickson
    39 olde hall rd.
    Hebron, CT 06248
    Cell Phone: 860-841-0504
    Home phone: 860-530-1325
    Mom's Work phone: 860-486-4120 You may get results with her. who knows.
    Derrick's email: DHendrickson117@gmail.com
Posted 10 September 2009 - 08:30 PM
Car? Milage?
Just because it works doesn't mean it isn't on its way out...
I have one from a 98 V70 R if you're interested...
Deadbeat, owes people money.
39 olde hall rd.
Hebron, CT 06248
http://volvospeed.co...0
#3 Ozark Lee
Ozark Lee
  • 1,400 posts
Posted 10 September 2009 - 08:34 PM
Quote
That is a monumentally bad idea. The battery acts as a voltage regulator on the charging system and it is easy to spike the ECU and the rest of the electronics to run without the battery hooked up. It is worth a second opinion from another auto parts store but the alternator testers have a load bank that forces the alternator to run at or near its rated capacity. When it is just keeping the motor running it is loafing.
...Lee
'98 S70 T5
'96 850 Platinum Edition Turbo
'96 850 N/A
'94 850 N/A
Previous: 1989 740 GLT , 1986 740 GLT, 1972 142 Grand Luxe
#4 ceesenacho
ceesenacho
  • 15 posts
Posted 10 September 2009 - 09:19 PM
im sorry
94 auto 850 na 78k
so whats the next best way to test other than disconnecting the battery
thank you
Car? Milage?
if it will fit/work how much should i pay for yours
#5 DHV70
DHV70
  • 576 posts
    39 olde hall rd.
    Hebron, CT 06248
Posted 10 September 2009 - 09:40 PM
View Postceesenacho, on 10 September 2009 - 09:19 PM, said:
im sorry
94 auto 850 na 78k
thank you
I'm not sure about the fit....
I had it tested, and it works fine - 50 bucks + shipping and its yours.
39 olde hall rd.
Hebron, CT 06248
