i had the belt that runs to my air conditioning unit snap and mess up my harmonic balancer. now im running my car with no air conditioner would it be fine to take the air conditioning unit out?
1988 Volvo 740 Air Conditoning Unit
Started by Big Jx253x, Sep 17 2009 10:57 PM
8 replies to this topic
Posted 17 September 2009 - 10:57 PM
Posted 18 September 2009 - 01:45 AM
sorry i forgot to put that the reason the belt snapped is cause the air conditioning unit froze up. im not really worried about air conditioning where i live so i was thinking about getting rid of the whole unit.
Posted 18 September 2009 - 01:57 AM
Im not 100% sure on what all that connects to, but I do know that those compressors work on 850's
Also I would say it was most likely the clutch that went out and again not knowing how it works 100% but seeing the car my compressor came off of, it might work. Someone else might want to chime in here. But as long as it isn't connected to any other main things you should be ok.
Posted 18 September 2009 - 03:15 AM
well ive been running it like this for about 6 months. i just want to make certain before i take it out.
Posted 18 September 2009 - 07:35 PM
My 91 740's AC died years ago, I just removed the belt and let it hang out in there
, no need to remove it if the belts not hooked up.
DAVE
96' 850R
96' 850R
Posted 18 September 2009 - 10:16 PM
Removing the compressor will cause no issues. If you might ever want to have AC again, I'd recommend leaving the compressor in place until it is replaced. Make sure you vent the freon via an schrader valve before removing any lines, otherwise the potential pressure can make them exceedingly dangerous to remove.
Posted 19 September 2009 - 12:38 AM
well i was told my windshield defroster worked off my air condtioner so i wanted to see if that was true or not before i removed it.
Posted 19 September 2009 - 06:45 PM
Well I'm not certain about specific 740s, especially MCC type controls, but IINM with ECC type controls, it does normally run the AC compressor when in defroster mode, however, you don't have a working AC compressor, thus the issue is moot. With non functioning AC, your defroster function will still work but be much less effective, especially with a lot of moisture inside the car, where you will have to rely on the heater alone. Just be ready to deal with fogged up windows.
