Have you experienced this painful situation?
Coolant Expansion Tank
Started by tenn850, Sep 18 2009 05:13 PM
4 replies to this topic
Posted 18 September 2009 - 05:13 PM
I had a cracked plastic near the small pipe on the top the expansion tank and was leaking antifreeze. So went around and found a similar used one and cleaned and installed. Now the dash light for low coolant level is on! So looked into it and found out the floater (ring) in the tank doesn't float! It stays at the bottom when the tank is filled to normal level.
Cleaned it more and again the same thing. It actually moves if you flip the tank upside down..
95 850 GLT
Posted 18 September 2009 - 05:17 PM
I have not experienced this but it is common.
Just swap in the float from your old tank. If you already threw it away then it's time to buy a replacement ...
Posted 18 September 2009 - 05:19 PM
Unfortunately it can not be opened! It is a one piece deal.
95 850 GLT
Posted 18 September 2009 - 06:00 PM
The sensor itself is removable. I've done it a few times and in fact I even have a spare tank and sensor sitting in front of me.
A bit of warning though, if you use a plier to pull it out, it could break it (I broke one like this).
1998 Volvo S70 T5 Red AT - Stage Zero completed, ARD Orange Tune, ARD Lightweight Crank Pulley. iPd HD endlinks, CJ's Strut brace, iPd Anti-Sway bars, Bilstein TC struts, AC Delco TCV Valve, iPd stainless steel braided brake hoses, StylinMotors silicone vacuum hoses and intercooler hoses, SC-901 w/ Center channel and prologic processor, Planet Audio 400W 4ch Amp, Blitzsafe AUX in adapter, Homelink Visor, rear armrest cupholders, LED sidemarkers, rear mudflaps, and the list goes on and on...
2007 Volvo S80 V8 Silver - Stock.
Posted 18 September 2009 - 11:11 PM
If you keep an eye on thing like your coolant level, you can try unplugging it.
Suprisingly, it will not give you the low light unplugged.
My has been unplugged since before I got the car a year ago....
