Cheaper Place To Buy Turbo Drain Pipe Tool?
9 replies to this topic
#1 randomdude
randomdude
  • 2,383 posts
  • Gender:Not Telling
Posted 18 September 2009 - 06:07 PM
alright, so both the gasket and seal are leaking on my oil return pipe. it looks this tool is going to be the only semi-easy way to do the job. but $36 for one socket :o . does any one know a cheaper place to find the 5mm allen key swivel socket for this? the local sears/auto parts houses, and home depot i believe, had nothing of the sort. and im worried that if sears doesnt have it no other place will.
thanks.
my 854T5 with a nice list of mods was totaled by a dumb girl driver :(
1991 780TIC-RARE!-named "roxanne" by the GF.-more pressure-less restrictions-plenty of suspension bits to come!
#2 adamjjohn203
adamjjohn203
    Steve
  • 1,960 posts
Posted 18 September 2009 - 06:18 PM
thanks.
Just use a standard allen key....works just fine. It is a little easier on a long screwdriver with allen bit.
#3 the commissar!
the commissar!
  • 2,024 posts
  • Interests:interesting things...varies with temperature and altitude
  • Crew:ECC
Posted 18 September 2009 - 06:45 PM
thanks.
I just use a standard allen head socket on an extension...If you need, add a u-joint in there. Should be fairly easy unless you have AWD but your sig says T5 so give it a go.
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted ImagePosted Image
#4 Cal3thousand
Cal3thousand
  • 2,065 posts
Posted 18 September 2009 - 07:37 PM
I agree with the 2 guys above. I've never even heard of a special tool for it.
I also ended up replacing them with regular hex bolts after the originals "fell" out.
1994 854 Turbo
#5 Chilled Man
Chilled Man
    MILFSPEED
  • 30,087 posts
Posted 18 September 2009 - 10:03 PM
If you have AWD you must have that tool
If you dont just use a standard allen key
trust me you will spend hrs trying with out the tool and awd
#6 randomdude
randomdude
  • 2,383 posts
Posted 19 September 2009 - 12:50 AM
awesome guys, thanks for the help! might just get this done this weekend now. :)
#7 DHV70
DHV70
    Deadbeat, owes people money Derrick Hendrickson 860-841-0504
  • 576 posts
  • Interests:Derrick Hendrickson
    39 olde hall rd.
    Hebron, CT 06248
    Cell Phone: 860-841-0504
    Home phone: 860-530-1325
    Mom's Work phone: 860-486-4120 You may get results with her. who knows.
    Derrick's email: DHendrickson117@gmail.com
Posted 23 September 2009 - 08:30 PM
my least favorite part about this past weekend
Deadbeat, owes people money.
39 olde hall rd.
Hebron, CT 06248
http://volvospeed.co...0
#8 Mogatu'r
Mogatu'r
    Shiny Performance Racing.
  • 2,886 posts
Posted 24 September 2009 - 04:34 PM
Everytime I remove these, I also replace them with reqular metric hex bolts, I believe they are m6 with a 10mm hex head.
brinquedo 00R-M 309hp/385tq / '97-855R 26k miles on Volvo rebuild, Weitec kit / daily... 98 v70 t5 wifey...E36 m3 cooling system overhauled:check:
#9 TyConn
TyConn
    Delta Bravo
  • 900 posts
  • Interests:Wings 'n Things
Posted 25 September 2009 - 12:17 AM
AHAHAHAHAHAHAHHHA
HAHAHAH AHAHAH
so, i heard it's easier if you take the turbo off first.....
1998 V70 T5 M
1994 854M Silver on Black
1998 Black on Black S70T5
1998 S70 GLT
1990 245 DL M47
...RIP at 320K
#10 Budnapp
Budnapp
  • 15 posts
Posted 26 September 2009 - 11:30 AM
Did my 98 V70 AWD this weekend in about 20 minutes. Used a standard allen key and allen socket with a long extension. It's a little tight but it can be done.
98 V70 AWD
