Evap System Intake Mani Hose Whatwhat?
4 replies to this topic
#1 T5power
T5power
  • 4,773 posts
  • Interests:Underwater Basketweaving
Posted 19 September 2009 - 12:15 AM
so i've had a CEL staring me in the face for a while now, PO442, small evap leak. replaced the gas cap, still there. so i was in my engine bay a few days ago and found this:
that black rubber hose coming from the charcoal canister is cracked. i'm really hoping that's the only place it would leak from, i mean when i held the hose it turned into dust, so it needs replacing anyway. my question is; where the f*ck do i find a replacement for that?
///T5
#2 JordanW
JordanW
  • 398 posts
Posted 19 September 2009 - 12:41 AM
That in your hand is the check valve for the SAS solinoid on the header panel/ fan shroud. The elbows/connectors are available from Eeuroparts.com, FCPGroton.com, IPDUSA.com
Your sig says you have a s70, so I would check the J hose on the charcoal canister, under the car, back by the fuel filter.
*-J-*
#3 T5power
T5power
  • 4,773 posts
Posted 19 September 2009 - 01:26 AM
well poop. i thought it would be just that easy :lol: <----- this noob doesnt have (easy) access to a lift, although i can pull some strings.
thanks for the heads up, much appreciated. :) :tup:
///T5
#4 Chilled Man
Chilled Man
    MILFSPEED
  • 30,087 posts
  • Gender:Not Telling
Posted 19 September 2009 - 03:14 AM
100% correct you can replace that line with Silicone Vac lines from Stylin ;)
#5 Modus
Modus
  • 693 posts
Posted 19 September 2009 - 04:54 AM
Or that O -ring on the canister
http://volvospeed.co...__fromsearch__1
