Where To Route Wideband/Egt Wiring?
11 replies to this topic
#1 Wagoneer855
Wagoneer855
  • 3,186 posts
  • Crew:ECC
Posted 24 September 2009 - 08:41 PM
Is the only option for running the wideband and EGT wires (which are larger than most) drilling a hole in the firewall and routing them that way? The pass through is way too small. The only option you'd have there is cutting the connectors off and reconnecting them on the other side.
Any other suggestions would be great, I'd like to get this finished tonight.
'97 855 - Build in progress
#2 Pops Racer
Pops Racer
    Old Man Crew Leader
  • 4,744 posts
  • Interests:Playing my violin around fires
Posted 24 September 2009 - 11:08 PM
Hey dude, I did my Wideband harness thru the existing firewall conduit. I did a pictorial of it, I'll try to find it and give you a link. Not too hard actually. Give me a bit of time.
Why would you get a minus 2? It's a legit question.
"Property is the fruit of labor...property is desirable...is a positive good in the world. That some should be rich shows that others may become rich, and hence is just encouragement to industry and enterprise. Let not him who is houseless pull down the house of another; but let him labor diligently and build one for himself, thus by example assuring that his own shall be safe from violence when built." - Abe Lincoln
#3 Wagoneer855
Wagoneer855
  • 3,186 posts
  • Crew:ECC
Posted 25 September 2009 - 01:02 AM
People are minus happy on this site. Any thread without a picture of a volvo with a giant turbo gets a minus... or anything Dave posts :lol:
Anyways, I routed it through the door, I cut out a portion of the door seal and squeezed the wire through it. Doesn't kink, totally proected from water, and the harness goes straight up to the strut brace so it's protected from the heat. Works perfectly! Saved me tons of trouble rather than drilling another hole through the firewall.
I don't have anymore room in the firewall pass through. The EGT wiring was the last thing that would fit.
#4 lookforjoe
lookforjoe
  • 8,316 posts
  • Interests:Making Stuff
Posted 25 September 2009 - 02:06 AM
You don't have to cut the connector, just remove the wires from it... that's what I did to get it through, along with lots of silicone spray. My pass through is packed! (Wideband, Apexi, boost, EGT, etc...)
#5 Wagoneer855
Wagoneer855
  • 3,186 posts
  • Crew:ECC
Posted 25 September 2009 - 02:08 AM
Haha, so is mine. I have EGT, boost, switch for my halos and wiring for my duel stage boost controller. So there was no way I was fitting the wideband harness through there.
The door technique works awesome though, I don't know why more people don't do that.
#6 volvoluvin
volvoluvin
  • 669 posts
  • Interests:Lots
Posted 28 December 2009 - 08:14 PM
Just about to install my WB...I was hoping some pictures or a better description would be available?
And I'm wondering if Wingnut ever found the link to his write up?
thanks
"Yarth" - 95 T5-R(m) - 18t,r-mani, 3" custom DP, EST 2.5 Cat back, IPD Stage III tune, MBC @ 17psi, RIP Kit, Sconeman Post Maf goodness, IPD plug wires, MSD ignition,IPD Short Ram intake, IPD Sways, Koni FSD's with Eibachs, 18" pegs, M56H with Quaife LSD and short shifter plate
#7 Naughty33W
Naughty33W
  • 1,646 posts
  • Interests:workin on my S60 and getting a divorce
Posted 28 December 2009 - 08:19 PM
my boost gauge is routed through my fender and then through the door jam rubber thingy , works fine and keeps the line away from other stuff
2003 Volvo S60 2.4T --- Favorite VS quote - "28 psi boost spike = ... fu** me lol" - by: 83' Turbo
18x8" OZ Wheels in Black , Gutted Interior , Smoked Windows , And Yes ... Hood Pins ...
Engine Build: 16T + Garrett WGA + Mishimoto FMIC + 3" Catless (Meow) TurboBack Exhaust + Tweaked ST 17psi Tune
#8 854TGA+
854TGA+
    Old Man Crew Border Guard
  • 1,957 posts
Posted 28 December 2009 - 08:58 PM
I have EGT / WB / TPS / Tach / Turbo Tuner / Boost/ IDC all coming through firewall grommet behind glove box :D Mind you we need a shoe horn to make them all fit :lol:
1994 850 Turbo
#9 L8 APEKS
L8 APEKS
  • 760 posts
  • Interests:I LIKE TO RIP PEOPLE OFF.
    http://volvospeed.com/vs_forum/index.php/topic/135080-wheres-l8-apeks/
  • Crew:LBC
Posted 28 December 2009 - 09:14 PM
I ran mine through the steering column tunnel. The opening is huge, and it's just a rubber seal blocking it off. Not even a full fledged grommet.
I have NO idea why people ever recommend to drill a new hole with that huge gaping hole already there!
#10 volvoluvin
volvoluvin
  • 669 posts
  • Interests:Lots
Posted 28 December 2009 - 09:19 PM
Thanks everyone for the quick reply! People must be back at work... :lol:
I like the idea of the steering column, sounds simple enough...
#11 BoostedBrick
BoostedBrick
  • 61 posts
Posted 29 December 2009 - 01:38 AM
Quote
I also used this location for my wideband. There is a convenient ground location in the passenger foot well also. I tried to get a pic but it was with a cell phone in the dark and it was snowing so I didn't try too many times haha.
The wideband controller is zip tied near by, and you can see the wires running to the grommet, which I tried to pull out a little so you can see it better (can see yellow behind it). There is a fair amount of room there for more wires too.
Hope this pic helps, please excuse the dirt and snowflakes!
1996 850 Turbo
ST 17psi tune on a 16T Angled Flange Turbo
Silicone Hoses, MSD Coil, K&N Filter, H&R Springs, Bilstein HD
#12 volvoluvin
volvoluvin
  • 669 posts
  • Interests:Lots
Posted 29 December 2009 - 03:22 AM
This is how i ended up doing mine:
worked like a charm...
