1996 - 1997 850 Turbo Manual Swap Ecu Options?
7 replies to this topic
#1 blkaplan
blkaplan
  • 844 posts
Posted 25 September 2009 - 02:25 AM
I am going to be converting my 96 850R to a m56 and I need to know some info about my options for the ECU. In the state of MD they require the OBDII systems to stay intact and that's the only thing they check for in our emissions tests every 2 years.
I have heard that the car won't run very well with the 850R auto ECU, correct? Will it actually throw codes or just run poorly?
Will a euro ECU from a turbo 96-97 car have the obdII system and will it work?
Can anybody reflash an ECU with a manual tune that will keep everything happy?
I tried to do some searching but it seems like this info is still evolving so was hoping to get the most update to date info.
Thanks guys!
1984 242 Turbo, 1988 245 +T, 1995 960, 1996 850 R
#2 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 25 September 2009 - 02:46 AM
Keeping the auto ECU will throw a code for missing trans ecu
you can get it to where just the manual switch is flipped.....IPD can do it
or if you want to tune also, try checking with TurboTuner
#3 blkaplan
blkaplan
  • 844 posts
Posted 25 September 2009 - 02:55 AM
So what you are saying is the car will drive fine but throw a code for missing TCU?
Can you change the fact that it looks for auto or manual with TurboTuner?
#4 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 25 September 2009 - 12:31 PM
The car doesn't run ideally with the auto ECU in and the TCU missing, but it definitely runs okay and relatively safely. The fuel cut is more noticeable as are the drops in RPM....besides that there is not much different. And yes, your arrow will be flashing indicating a missing TCU...code will be stored for it also.
with turbo tuner, they haven't come up with a way to flip it in real time using the software (unless something has changed in the last 2 months)....however, when you order one, you indicate whether you want for manual or auto....i think they were working on an "on the fly" switch within the software.....you can contact the vendors of TT for updated info.....benefit is that you can tune yourself and change tunes on the fly as you wish...you can also keep the car OBDII compliant for CA and MD.
And if you go with a RICA or IPD tune, see if you can specify that you don't want a euro/canadian tune...those are not OBDII compliant...you may run into problems plugging in the scanner to diagnose/read.
#5 turbotuner
turbotuner
  • 206 posts
Posted 25 September 2009 - 01:26 PM
Actually, the good news is that we are just finishing testing a manual swap smog compliant OBD2 enabled solution. This should be available by the end of September. More details will be available later. :)
Turbo-Tuner USB - DIY Tuning for Volvo Bosch Motronic 4.3 and 4.4
http://www.turbo-tuner.co.uk
http://support.turbo-tuner.co.uk
#6 blkaplan
blkaplan
  • 844 posts
Posted 25 September 2009 - 02:09 PM
Well its the 25th already so we should expect to hear something within the next few days. Right?
#7 flyfishing3
flyfishing3
    100% Vegan
  • 12,651 posts
Posted 25 September 2009 - 02:12 PM
didn't lostartof have something?
Double R garage
i was so drunk last night, i thought the toothpaste was astronaut food.
#8 turbotuner
turbotuner
  • 206 posts
Posted 25 September 2009 - 02:19 PM
Yep, some time next week.
