How To Test Cam Sensor?
9 replies to this topic
#1 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 01 October 2009 - 10:27 PM
no spark. 2 diff ecu's, no spark. no spark at coil. no signal to ignition mod. checked continuity from module back to ecu, continuity good. what would make ecu pull spark? bad cam sensor? how do i diagnose cam sensor? any other possibilities? thanks all
1996 855R
#2 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,479 posts
  • Gender:Not Telling
Posted 01 October 2009 - 10:31 PM
Codes prior to swapping parts?
98 S70 T5M
#3 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 01 October 2009 - 10:36 PM
no. this is a re-install being started first time.
1996 855R
#4 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 02 October 2009 - 06:30 PM
N E 1? the rpm sensor is fairly new. what can cause computer to pull spark?
1996 855R
#5 Black Betty
Black Betty
  • 6,987 posts
Posted 02 October 2009 - 06:35 PM
did you put the sensor in upside down? if you need anything let me know im parting a 96R
#6 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 02 October 2009 - 08:04 PM
pulled a P0120, throttle pos sensor. i'll run that one down next
1996 855R
#7 Cal3thousand
Cal3thousand
  • 2,065 posts
Posted 03 October 2009 - 12:21 AM
Look at the Fuel Injection relay. I had a no spark situation with the TPS ground circuit code that was caused by bad wiring to the relay. Its located on top of the fan shroud near the drivers side. Another thing you will notice is that with the key in the ignition in the II position, the check engine light will not light up as it normally does before starting. If you see the Check Engine light working like normal, its not the FI relay.
1994 854 Turbo
#8 Black Betty
Black Betty
  • 6,987 posts
Posted 03 October 2009 - 12:34 AM
if you needs i gots
#9 ajhehr
ajhehr
  • 880 posts
Posted 03 October 2009 - 01:15 AM
check your crank sensor, also make sure you pinch any wires...
#10 Hoosier Daddy
Hoosier Daddy
  • 622 posts
Posted 03 October 2009 - 03:43 AM
very interesting, will check. thanks for the feedback. i have another TB that i'm going to swap in and see if that helps
1996 855R
