1991 940 Turbo Wagon
9 replies to this topic
#1 Guest_Bart Wheaton_*
  • Guests
Posted 03 October 2009 - 11:59 PM
The car starts and runs for a while, then it starts to cut out after about 10 minutes or so until it finally dies and does not start again for some time. Then the cycle is repeated, also worth noting the check engine light comes on right before it dies. I have replaced the high pressure fuel pump and the pump relay. Any suggestions?
#2 GrandmaSideways
GrandmaSideways
  • 42 posts
Posted 04 October 2009 - 01:43 AM
Have you tried checking to see what code it gives you?
OBD 1 is stupidly simple.
#3 Guest_Bart_*
Guest_Bart_*
  • Guests
Posted 04 October 2009 - 01:53 AM
I am not familliar with the codes.
#4 Guest_Bart_*
Guest_Bart_*
  • Guests
Posted 04 October 2009 - 01:56 AM
what are these codes and what is obd 1
#5 GrandmaSideways
GrandmaSideways
  • 42 posts
Posted 04 October 2009 - 02:42 AM
OBD1 is the diagnostic equipment.
It pre-dates the pkug in computers and it's a black box you access, then you basically count out the flashing lights.
I can't remember the exact procedure unfortunately.
#6 otis44
otis44
  • 5 posts
Posted 04 October 2009 - 02:51 AM
I had a 93 a while back that did kinda the same thing, it turned out to be the ignition module. It is mounted on a heatsink on the fender wall just before and above the battery. Heat is known to cause these to go bad, mine would run fine on short trips around town but on longer drives it would die intermittently.
#7 Three Fat Tigers
Three Fat Tigers
    RWD Moderator
  • 1752 posts
Posted 04 October 2009 - 03:43 AM
ODB1 codes and procedure can be found here:
http://www.brickboar...ineOBDCodes.htm
I would start with that.
#8 Guest_Bart Wheaton_*
  • Guests
Posted 04 October 2009 - 05:35 AM
Thanks I googled volvo OBD codes and came up with that site. i will try it tommorrow and let you know what happened
#9 Guest_Bart Wheaton_*
  • Guests
Posted 04 October 2009 - 06:50 PM
It is the Crank Position or RPM Sensor. thank you for all your help this is a very helpful site.
#10 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4761 posts
Posted 05 October 2009 - 12:33 AM
Thank you for joining our VS crew
"SMOKE TROUT NOT CRACK"
