Highway Vibration 01 S60 2.4T
Posted 04 October 2009 - 08:43 PM
So my car has been vibrating at or above speeds of 45 MPH, it is most noticeable after 60 MPH.
I was hoping that replacing the transmission engine mount would make a difference but I don't think it did.
This vibration comes only from the left front wheel under load/acceleration. It happens with and with out cruise control.
I think it is the worst when accelerating between 60-75 MPH or travelling at those speeds.
I don't think it is the wheel since it doesn't vibrate when coasting. I am not sure what else to check although I will rotate the wheels next weekend, front to back.
Also it seems to vibrate worse when the car is loaded.
I imagine this is probably some bushing issue? I don't think it's serious, but it annoys the shit out of me. Where do I start looking?
96850_R, on 16 August 2009 - 11:23 PM, said:
Posted 04 October 2009 - 08:56 PM
2001 S60 T5 - 18T - Vibrant FMIC - Full 3" straight no muffler dual Magnaflow resonators - BSR Stage III PPC - Green Injectors - K&N panel - Snabb intake - AEM Uego controller - silicone vac lines - QBM Mounts - 17" Falken RT-7M wheels - Elevate front sway w/ TKI HD endlinks - IPD rear sway w/ HD links - Blackout Eggcrate grill - painted eyebrow tails - M Rear Lip spoiler - Koni/Eibach FSD's - R Manifold - Sharp HIDs - 3M Di-Noc CF console[/center]
Posted 05 October 2009 - 12:43 AM
s60wot, on 04 October 2009 - 08:56 PM, said:
Grab the axle and give it a shake
You will be able to feel if it's bad
Also, you may have some grinding or crunching sounds turning a low/slow speeds
Posted 05 October 2009 - 04:02 PM
Could be tons of different things.
I'd start with rotate, balance, & align the tires. Check for unusual tread wear also. This is the #1 cause.
Then go on to what components have gone bad (my first guess - lower control arm bushings).
Posted 06 October 2009 - 05:27 PM
I imagine this is probably some bushing issue? I don't think it's serious, but it annoys the stuff out of me. Where do I start looking?
Hey,
I have this exact same problem with my 99 S70 glt. Its not the alignment or the tires. It also does it only under load, however mine is worse between 50-65. I replaced the top engine mount just because it was shot and so I did, but it did not help at all. The tie rods were replaced a few months ago, so I am pretty sure I can rule those out too. Everyone who replied to my post said cv. Keep me apprised as to what you find out and I will do the same.
Teal
Posted 08 October 2009 - 12:07 AM
Posted 15 October 2009 - 03:29 AM
I replaced the boot once before because of a rock, but due to the amount of miles I had to drive on it didn't want to chance it. Just replaced the entire axle earlier today.
But while highway driving, lots of boost lots of WOT btw, I noticed the car pulled left under braking. I assume was because of the axle bearing getting wore down (passenger's side). But I replaced it today - still pulls left but not as hard. Possible the driver's axle needs some R&R also?
