Captain Bondo, on 08 October 2009 - 04:08 PM, said:
That means pretty much nothing if the hotside is choking, you have some of the most scrawny camshafts ever designed, a cast iron exhaust manifold, and an intake tuned for low rpm. More things influence the powerband than just the compressor map as you probably realize. The turbo hotside has a bigger influence than the coldside imo.
Your airflow assumptions are correct, but assume optimal timing and AFR which are unlikely unless you have actually tuned the motor. The more appropriate reference is that torque will be highest where injector pulsewidth is widest, and horsepower will be highest where injector duty cycle is highest, again assuming a steady afr and appropriate timing.
The OP is on stock exhaust. From my personal experience with a lot of these mild setups, every car with stock exhaust will behave this way. With a nice exhaust, even with the TD04HL and stock manifolds, you'll be back to a freely rising powerband to 5500 or 6000, depending of course upon boost levels and boost fade. As for torque, that is going to continue to peak in the 3000s until your turbo's hot side flows better.
I have superimposed dyno charts from the same dyno of a 19T at 16 psi, and a T3/T04E 57 trim at 16 psi. They are really remarkably similar peak numbers-wise. It doesn't bear posting on here because the 19T dyno graph is basically trash due to boost fluctuations (it was ECU-controlled at the time, and would bounce between 14-17 psi).
What is interesting, is that the 19T still has over 200 wheel torque at the 6450 RPM limiter. The torque curve looks like a roller coaster due to the boost fluctuation, but if it were steady I think it would be peaking around 3500 RPM and be well over 300 (maybe 310-320). Power looks like it would peak at 5000-5500 somewhere. Though the peak power on that run was made at the limiter, I guess boost came back in at that point.
For comparison, the 57 trim T04E compressor (with the standard .63 AR T3 turbine housing and stage 3 T3 turbine wheel) has a torque peak at 4300-4500 RPM of ~265, and falls to around 175 wheel torque at 6500 RPM. This setup also had NA cams though IIRC. Power certainly does not fall off though with this turbo. It breaks up a bit higher in the RPM range, but certainly does not fall off much.
While the actual numbers are interesting because the TD04HL is actually a bit higher and certainly has more area under both curves at the same boost level, there are some big variables different despite being the same dyno. Air temp with the 19T was 88 degrees F, and with the 57 trim it was 114 degrees F. I hardly think the intercooler could be doing much with a mere fan pushing 114 degree air across it. Edit: the 57 trim's dyno run was also done on 15" drag radials at ~15 pounds of pressure. So slightly different gear ratio as well as a tangible bit more parasitic loss due to the softness.
Still, there is some value to the comparison. It shows that the TD04HL, albeit a small hot side, can still make power (and torque) higher in the rev range. It is still geared toward a peak torque in the 3000s, but it generally has a huge peak torque level and although it's falling off continuously thereafter, it still makes numbers. IMO it's underwhelming to drive, but it certainly moves a car well.
