Fuel Filter
8 replies to this topic
#1 95 R
95 R
  • 25 posts
Posted 21 November 2004 - 12:35 AM
What type of fuel filters are people using? How hard is it to replace a fuel filter on an 850?
1995 850 T5-R
#2 Bay13
Bay13
  • 6,378 posts
Posted 21 November 2004 - 12:52 AM
http://www.volvospeed.com/Repair/fuelfilter.htm
#3 sp5368
sp5368
  • 686 posts
Posted 21 November 2004 - 02:37 AM
I just replaced mine 97 850 it took me about ten minutes to change
#4 KLS
KLS
  • 727 posts
Posted 21 November 2004 - 10:28 PM
One you understand how to release the end fittings it's easy. I put 100,000 miles on my original filter. When I renewed the fuel pump, I removed the filter to release the pressure in the fuel system and put in a new filter at that time.
Ken
#5 hutchwashere
hutchwashere
  • 30 posts
Posted 22 November 2004 - 02:42 AM
So - how do you remove the fittings at the end of the filter? I'm not sure I understand what the instructions mean at Bay13......
Thanks for the pointers!
-Joe
1995 Volvo 850 GLT 170,000
#6 mikie
mikie
    I got mad Heico flava son!
  • 1,037 posts
Posted 22 November 2004 - 02:55 AM
QUOTE(hutchwashere @ Nov 21 2004, 08:42 PM)
-Joe
Push it outwards, at first it was annoying me, but take a flat srewdriver, it has like a little clip if i remeber correctly.
#7 blazen244
blazen244
  • 280 posts
Posted 22 November 2004 - 02:56 AM
Five minutes to change real easy
95' 850 T-5
09' Suzuki GSXR 1000
Caddy Escalade
#8 gray1g
gray1g
  • 101 posts
Posted 22 November 2004 - 03:01 AM
just changed mine on my 95 850 turbo last week. I pulled the fuel pump fuse then started the engine till it died. This was done to release the pressure. From there just pry the clips off the filter like everyone is saying to do. It's ver easy! One tip though don't bend the bracket that holds the filter on. You'll have a hard time lining the holes up fro the bolt to go in.
1995 850 Turbo Wagon
K&N drop in
Speed Tuning chip 17psi
Stage -.5 almost stage 0
Sold
#9 sp5368
sp5368
  • 686 posts
Posted 22 November 2004 - 03:59 AM
There should be a schreader valve bicycle tire tube valve somewhere around the fuel pump release the fuel pressure by pressing in the needle in the middle, grab the filter and pull the connecter toward the rear of the car and it should release (MAKE SURE YOU RELEASE THE CLAMP HOLDING THE FUEL FILTER)
