Manual Transmission
19 replies to this topic
#1 Patrick.
Patrick.
  • 5,707 posts
Posted 21 November 2004 - 01:46 AM
I'm sure I should already know this, but I was wondering how I go about changing/lubricating my manual transmission... Is there a place to fill it? Is there a dipstick? Does it even exist?! I'm clueless here, but I'm sure my standard transmission HAS to have some kind of oil that I should change... thanks for your help.
Pat M.
#2 REVolution T5
REVolution T5
  • 213 posts
Posted 21 November 2004 - 02:53 AM
free bump smile.gif i'm curious about this one too 'cause my stick feels kinda stiff when it's cold outside
user posted image
'98 s70 T5 - manual
#3 Bay13
Bay13
  • 6,378 posts
Posted 21 November 2004 - 02:17 PM
There is no dip stick only fill and drain plugs. The level is correct when it starts coming out the fill hole. The oil used in the manual transmission is 5W30 synthetic motor oil.
#4 spottieottie
spottieottie
  • 860 posts
Posted 21 November 2004 - 02:28 PM
QUOTE(Bay 13 Admin @ Nov 21 2004, 07:17 AM)
I have a dipstick, am I special?
'96 850 Turbo Black 'n Tan---------------FOR SALE!!!!!!!!!!!!
'98 S70 T5M black/ black ----- PARTING OUT let me know what you need.
2000 Suzuki DRZ400E desert pony
2006 Suzuki SV650S power wheelies are FUNN!!!
#5 chieffo
chieffo
  • 186 posts
Posted 21 November 2004 - 02:29 PM
where are these fills and drain plugs and how hard could it be to add or change the oil?
1993' 850 glt N/A 5 speed Red
K&N Panel Air Filter
Optima Red Top Battery
Stock OEM Spoiler
Sound: Kenwood tweeters, Pioneer TS-A530P 5.25" in front door, Infinity Kappa perfect 6x9 in back, 10inch Sony Xplod Sub
N/A Represent
Looking for an R for under 7k
#6 spottieottie
spottieottie
  • 860 posts
Posted 21 November 2004 - 02:34 PM
QUOTE(chieffo @ Nov 21 2004, 07:29 AM)
What would we have to do to flush it as well? But first things first ^^^^^^^^^??
#7 BlueTank
BlueTank
  • 24 posts
Posted 21 November 2004 - 03:52 PM
On my 99 V70 there are no recommendations for changing the M/T fluid. Kind of odd - but I can't even find a spot for a dipstick/drain/add.
#8 Bay13
Bay13
  • 6,378 posts
Posted 21 November 2004 - 04:20 PM
There is no dip stick for the manuals. There is no listed change interval, however I've found that 100K is a good time to change the oil. Take off the front left, (drivers in the USA) tire and you should be able to find the drain and fill plugs, I think the are 22mm.
#9 Patrick.
Patrick.
  • 5,707 posts
Posted 21 November 2004 - 10:13 PM
I'm going to change mine this week (132k and probably no change ever) I'll let you m/t guys know if it smoothes anything out at all.
Pat M.
#10 KLS
KLS
  • 727 posts
Posted 21 November 2004 - 10:16 PM
Be sure you're able to loosen the fill plug before you drain the oil.
Ken
#11 Patrick.
Patrick.
  • 5,707 posts
Posted 22 November 2004 - 12:10 AM
QUOTE(KLS @ Nov 21 2004, 06:16 PM)
Ken
GOOD CALL! smile.gif That would suuuuck
#12 Volvoboi24
Volvoboi24
  • 405 posts
Posted 22 November 2004 - 04:24 AM
QUOTE
I recently bought Mobil1 Synthetic 75w-90 gear lube?.. is this ok to use?
thanks in advance
Now: '06 BMW 530i // '98 S70 T5M
Past: '05 S60R // '98 C70 T5M // '95 BMW M3 // '94 855
#13 Patrick.
Patrick.
  • 5,707 posts
Posted 22 November 2004 - 06:34 AM
yeah, is 5w30 the only oil to put in the transmission? anything else? I want to make shifts as smooth as possible, my 5 speed has been a little stiff lately. Is there anything else I could do to soften shifts up a little?
Edited by 850Charisma, 22 November 2004 - 06:35 AM.
#14 Guest_Guest_volvoboi24_*_*
Posted 22 November 2004 - 11:19 PM
#15 BlueTank
BlueTank
  • 24 posts
Posted 23 November 2004 - 12:34 AM
If I recall right, 75W-90 is what I put in my toploader 4 speed for my 65 'stang.
Newer trannies seem to like the lighter fluid. Probably didn't hurt anything but it flows like sludge compared to the 5W-30 recommended.
I'd change it out at the first opportunity. But it is probably no worse for the wear.
#16 Bay13
Bay13
  • 6,378 posts
Posted 23 November 2004 - 01:16 AM
Use nothnig except 5w30 synthetic motor oil in the FWD manual transmission.
#17 Volvoboi24
Volvoboi24
  • 405 posts
Posted 23 November 2004 - 04:45 AM
Edited by Volvoboi24, 23 November 2004 - 04:46 AM.
#18 macmom
macmom
  • 128 posts
Posted 08 December 2004 - 03:33 AM
I have been using mobile 1 synthetic gear lube in mine, I just went and checked it and it is 75w90 blink.gif , is that bad, am I killing my transmission?!
QUOTE(Bay 13 Admin @ Nov 21 2004, 08:17 AM)
2001 V70 T5 82,225K, manual trans, black with graphite interior
RIP sold 95 855 GLT 255k manual trans, bilstein/TME, IPD sway bars, Slater's end links, engine block toast, all else good. Black w/tan leather, 3rd seat, arm rest booster seat in back.
1980 VW Pick-up CUTE ASS TRUCK
FOR SALE 1986 K5 Blazer (husband's money pit) BAD ASS TRUCK
NOTE:Automatic transmission models have 15ft/lbs less torque
#19 macmom
macmom
  • 128 posts
Posted 08 December 2004 - 03:34 AM
In understand, but could I have damaged it, I have had it for 100k? I think I might cry now.
QUOTE(Bay 13 Admin @ Nov 22 2004, 07:16 PM)
#20 Bay13
Bay13
  • 6,378 posts
Posted 08 December 2004 - 04:14 AM
I have no Idea what running the wrong weight oil will do, if you are sure thats whats in there, just change it.
My tires don't rub.
