Vibration Only When Accelerating Above 60Mph
14 replies to this topic
#1 C70drvr
C70drvr
    kitty forums rock
  • 5,175 posts
  • Interests:=3
Posted 16 October 2009 - 09:28 PM
When ever I accelerate from around 60mph, my car vibrates. The feeling is gone if I let off the gas of put it in N. If I accelerate hard in 3rd gear, the vibration is very strong.
The wheels are balanced and the car is aligned properly. There is no noise from the CV joints when driving around slowly and visually they look fine. No popping and clicking when turning. Just this vibration when putting the power down.
1998 C70 HPT Coupe - Factory 5 Speed Manual
IPD springs, HD seats, Koni adjustables, EST CF Strut Brace, short shifter, HIDs, 15% tint, NGK Iridium plugs, 15+20mm H&R Spacers, 18" Balius, Dunlop Z1 StarSpecs
#2 pio
pio
  • 74 posts
  • Crew:ECC
Posted 16 October 2009 - 11:48 PM
Hows your mounts?
1998 S70 T5 Auto
Samco hoses, IPD HD BSC, IPD Poly UEM, VDO Boost Gauge.
Stage 0 complete.
#3 GeraldJ
GeraldJ
    Professional Cow Fister
  • 1,496 posts
Posted 17 October 2009 - 01:09 AM
CV Joint
/thread
'96 855, Koni yellows, ipd springs, TT-USB
Eagle H-beams, Weisco pistons, custom cams
GT3071R, 60lb/hr injectors, Ported R Mani, W2A intercooler
m56h, 707 clutch, P&P'd head, CAI,
#4 rsleepr88
rsleepr88
  • 85 posts
Posted 17 October 2009 - 01:54 AM
it is most likely your inner cv joint on the pass. side as this will cause this. the pass. side axle is usually the one that goes bad 9 out of 10 times.
Doug
#5 franzdom
franzdom
  • 32 posts
Posted 17 October 2009 - 04:41 AM
Doug
I am having the exact same symptoms, where is a great place to get new ones?
'98 S70 48k miles
#6 C70drvr
C70drvr
    kitty forums rock
  • 5,175 posts
  • Interests:=3
Posted 17 October 2009 - 06:33 PM
The shaking is always much worse when I have a passenger in the car.
+1 about a good source to find one. I only want OEM Volvo parts.
#7 T-5Bandit
T-5Bandit
  • 1,848 posts
  • Crew:SCC
Posted 17 October 2009 - 07:02 PM
RAXLES is the best source. Complete rebuilds, lifetime warranty.
OEM is still going to be a rebuild and you are looking @400 from Volvo.
John
1998 V70 T5
Chrome 19" Niche Rhine Wheels
#8 Young Burnsy
Young Burnsy
  • 2,511 posts
Posted 17 October 2009 - 07:11 PM
I have the exactly same problem although it feels like the vibration is coming from the left wheel. OP where is your vibration located exactly?
2001 S60 2.4t / 137k mi / stock / 6k HID
View Post96850_R, on 16 August 2009 - 11:23 PM, said:
its some sort of home boy ghetto mesh shit
#9 GeraldJ
GeraldJ
  • 1,496 posts
Posted 17 October 2009 - 10:37 PM
My local o'rilleys has all new axels for $75. I have them and they are a bit beefier looking than the oem ones I replaced.
If nobody can get them locally email me I can arrange shipping.
#10 Young Burnsy
Young Burnsy
  • 2,511 posts
Posted 18 October 2009 - 12:53 AM
OE axles or what brand?
#11 GeraldJ
GeraldJ
  • 1,496 posts
Posted 18 October 2009 - 01:21 AM
Its a made in USA brand so I am sure its not OE.
I didnt put calipers on them but the shaft alone was about .25 bigger than the oem. The nut end was the same size as the splines, ie, no taper to nut size.
Came in a nice box with a new nut for $75 FOB. Had a card that explained that it was not a re-manufactured part and did not contain any reman'd parts. And best of all no core charge because they didnt reman the axels.
#12 C70drvr
C70drvr
    kitty forums rock
  • 5,175 posts
  • Interests:=3
Posted 18 October 2009 - 08:52 AM
It's spread out evenly. It is much more apparent with someone in the passenger seat.
#13 JordanW
JordanW
  • 398 posts
Posted 19 October 2009 - 03:02 AM
I'd still replace that right side mount. If it is worn and that side of the engine sits lower, it will change the drive shaft angle... albeit slightly, but perhaps just enough to cause you problems.
*-J-*
#14 jeff123
jeff123
  • 1 posts
Posted 29 November 2009 - 12:04 AM
I have the exact issue however some days mine is better or worse, but always is bad when i really step on it to get going, is the install of a new right CV joint hard? I have a 2001 volvo s80 t6 btw.
#15 DonutsDemise
DonutsDemise
  • 3,431 posts
Posted 29 November 2009 - 12:22 AM
the engine mount theory seems likely, you would hear snap crackle and pop if it were just the cv joint. the fact that you are putting a lot of torque on the mounts, twisting the motor in the compartment, would lead to the axles being forced to shift as previously mentioned. i would check this out before throwing money at parts you might not need, yet. stick a pry bar in there and see if you can shift the engine where the mount is.
Jake
1998 Volvo S70 T5M 183k
