corivus
New Here Some Photos Of My Ride
yup pcv is done along with vacuum hoses which where waaaaay to brittle, next is to switch to silicon intercooler hoses along with the radiator hoses. :)
Ended up having the HG go bad on me and after a lot of back and forth I decided to do an engine swap with the help of a friend because I got all kinds of crazy quotes, and nutty statements from other sources or people that just plain fell through on me, we got it to fire up last Friday but a few odds and ends had to be replaced I pick it up from my friend's place on Friday I'm excited :D It feels like we've put a lot of work into it over the past couple of weeks since we have only been working on one day out of the week. In reality we have all of 13 working hours into everything. I'm sure if I did this again in the future we could cut all of it down significantly. Here's what been updated
New engine from a 95 850R
Silicone Vacuum Hoses
New Radiator hoses
IPD Short Ram intake
Snabb Intake
New Poly Motor and Poly Transmission Mounts
New Dash from 95 850R
R Tune ECU
cv boots replaced
transmission seals replaced
new power steering pump and lines
blacked out grill
side marker signals
Climate Control Computer
Climate control module
Both Heater Hoses
heater hose firewall pass through
Heater Fan Blower Climate control unit
Thermostat
Expansion Tank
Coolant Expansion tank cap
Silicone intercooler lines
I discovered a few things that could wait till later to fix and those will be next up to replace and those were Cruise Control Pump, Horn Buttons, Horn Ring, and the odometer bezel gear. After pulling the dash that dash pad is stupid easy to remove and so is the steering wheel.
Next up:
Relocate horns
newer egg crate grill
Headliner sag repaired
new shocks
Replace Seat upholstery
NA TB and 960 TB plate
NA Intake
Repaint of bumper and lower trim
Either Get bottom half of 3rd Row seat or remove and put in the inserts without the third row seats
clear turn signals
There is probably a lot more that I've missed, but since today, I will post pictures when I get it back and detail the process which was a bit of a journey for me to say the least :|
Edited by corivus
updating with "I drove it from here to there" wasn't so interesting, it was mostly just saving bits and pieces here and there :)
once I had done enough I figured I'd update
Didn't know the Turbo's came with the Cetus wheels. I have some Volans or Columbas you might like better.
They don't :) that was something the PO did but I haven't been on the lookout for rims yet, when i do I'm thinking volans or tritons
So removed the old dash because anytime you'd accelerate the whole dash would come forward, my glove box was kinda sagging and I realized that the frame of the old dash was very much broken. Picked up a "newish" dash from a local member had to rebuild a few parts, but nothing some aluminum a rivet gun and a cutter couldn't fix. After about 30 minutes later we were ready to take the old dash out.
removed the dashpad and this bit crumbled:
after that we sorta pulled it out in chunks because it was basically destroyed and were left with this.
at this point I took the time to replace my Climate Control Computer, Climate control module, and heater hose firewall pass through, with those replaced it was time to put the new dash in.
I'm pretty happy with the results and there's a few things here and there that I'll need to replace down the road but it feels pretty nice to have a dash that doesn't move forward or creak or snap when you open the glove box. Sorry if the photos are blurry these are taken with my cell phone. As I said I pick it up on Fri and will take pictures over the weekend of how it looks afterwards when everything is in.
had a chance to take a few better shots, not going to post a lot of them because really a stock volvo 850 turbo is just that :) I haven't washed it yet mostly because I want to make sure all the odds and ends are done and then after that I'll have a full detail done, but it handles really well, just gotta get those bits listed earlier done and then I'll look into rims or going lower. I also picked up a set of blue led interior bulbs from prezman a while back and they light up the car in a bit more fun way. I may just switch to ultra whites eventually though
  • Similar Content
    • By Black_P2R
      I purchased a race downpipe for my 04 S60R from Snabb on February 5th. At the time it had a 2-3 week back order time. Knowing this I still ordered. It’s now March 4th, and I have yet to hear anything from them other than the order confirmation. I’ve called 3 times and left messages every time with no response. Has anyone had issues like this before? I’m really debating canceling my order at this point
    • By FrankenMoose
      Used Snabb Intake Pipe pre-fitted with PTC Element and Blue connection hose.  Also used BMC CDA carbon fiber Conical air filter.  Snabb pipe is a bit scuffed, but honestly you can't see it when installed. The air filter housing replaces the factory box and bolts directly to the stock MAF sensor housing. This setup is nice, and quite a bit louder than stock.  It lets you here the sneeze that is usually lost due to our recirculation system. I used to love to let it rev up to about 2 1/2 - 3 grand in first gear, then let it drop while driving around in my parking garage, just to hear the boost breath. Asking $200 + shipping for the setup. (MAF not included)
    • By Adam Franke
      One of these, new in box and never installed: http://www.vivaperformance.com/ultimate-intercooler-kit-s60-v70/
      I think the kit may have changed slightly since I ordered mine back in January of 2014, but that looks to be the same one based on the original sales receipt:
      FMK-P2 Ultimate Volvo Intercooler kit-S60-V70
      Turbo/turbo outlet type: K24 Vband - $55.00
      MAP adapter style: 03-09 Late style
      Silicone color: Blue
      One note, when I looked to install, I didn't actually have a Vband turbo, so I swapped out that connector for the correct standard K24 coupler. Asking $600 shipped, OBO.
    • By ForeroC30
      Hey all!
      I'm interested on making my 6-speed manual C30 T5 much more fun to drive, though it has a replay nice gearbox. I was looking for short shift systems for the car but I haven't actually find anything where to buy or any brand that makes one for the car.
      Does anyone has a short shifter in his C30, opinions, impressions.
      Also, where can i get one!?
      Thanks!!!!
    • By ForeroC30
      Hey guys!
      Im looking forward on improving the air flow of the turbo in my 2013 C30 T5. It has a tune, decatted DP, cat back, FMIC and the KN Air Filter with the GoVo ECU Spacer.
      I actually don't want to fit a full intake system simply because I don't like the idea of moving the ECU position, though I want to find the best way to give a breath to the turbo.
      Im considering the Elevate Intake Pipe or the Snabb Intake Pipe, I really can't decide between those two. The pricing is similar, just a little bit cheaper the elevate.
      What do you guys know, recommend, suggest?
      Please! I need to decide before I go back home.
      ps; not from the US
