Missing Cut Out For Light Bulb?
Started by !nooch!, Oct 23 2009 05:24 AM
8 replies to this topic
Posted 23 October 2009 - 05:24 AM
Today i had noticed the passengers side light in the rear wasnt as bright as the drivers side. the one that turns
on when you turn the lights on so i took the cover off (the one in the trunk lid) and saw a bulb missing from the
light pack i buy a bulb and it wont go in then i noticed the spot were the bulb inserts was never cut out is that
normal? what should i do drill it out? but i dont want plastic dust in my light. any ideas?
1998 s70 t5m
1998 s70 t5m
Posted 23 October 2009 - 09:29 AM
Not sure the if the s70s are different but with 850's there is no illumination on the trunk part of the rear lights- its just reflectors- anyone have any speculation?
Posted 23 October 2009 - 10:29 AM
The driver's side has a bulb there for your rear fog light. There should not be one on the passenger side. It would be reversed in Europe where they drive on the left side of the road. That's why the hole isn't cut out.
'98 S70 NA Silver Stock 220K
Toronto CAN A DA.
Toronto CAN A DA.
Posted 24 October 2009 - 01:34 AM
What he said.
Posted 24 October 2009 - 12:55 PM
ditto to the last 2 posts
Posted 24 October 2009 - 02:02 PM
actually i'm pretty sure in europe they run both fog lights, US DOT says that if both are on, people will think they are brake lights. but isn't that the whole point of having an extra bright light back there? to have people aware that you are in front of them? 2002+ audis (US spec included) run both fog lights too. i'm pretty sure there is a thread in Bay13on how to do it.... its not that hard anyway. pretty self explanatory
S70 T-5R
FMIC | Koni Sport & Kilen | LOLtune | 302JV Brake Kit | OBX(TBA)Magnaflow Catback | Gold Canistos | 6K Projector lows, 4.3k Fogs | T-5R Two-Tone interior | Red LED swap
LED's for X70's
Posted 24 October 2009 - 06:29 PM
+3, it is the rear fog light, US spec is for no second bulb there.
So if there is truly a difference in brightness (check it: are both bulbs usually on, on the driver's side?) and this isn't actually just a case of you noticed there is no second bulb, the difference may be because your fog light is permanently on. I would check the switch (maybe it is simply turned to "on" lol) or the wiring.
A common mod is to pull the housing out of a driver side tail from the junkyard, put it in the passenger side, then you can run both bulbs when you flick the rear fog switch.
on when you turn the lights on ...
'96 NA 855 | 207 k | wrecked, body not fixable, runs and drives like a (slow) top
'96 NA 855 | 92 k | daily driver
Posted 26 October 2009 - 06:14 PM
Thank you everyone for the explination im probally honna take the passenger side housing out and dremmil it so that
thanks again
thanks again
