More Boost?
18 replies to this topic
#1 riant5
  • 25 posts
Posted 23 October 2009 - 09:08 PM
so i have a stock 96 850, im pretty sure its a t-5 but i dont have any badging to prove it, how do find out what model it is???? but anyways, aside from that less important question, i was wondering if i could add a mbc to my stock setup and turn it up a couple lbs, maybe run 12psi? is this ok?
#2 850 LongBeach
    Cpt. Facepalm
  • 442 posts
  • Interests:Making Volvospeed fun and interesting, while at the same time getting banned for things I didn't do! Going 95+ in packed residential areas, and turbos that bend stock rods
Posted 23 October 2009 - 09:31 PM
12 Psi would be fine if it was a T5
install a boost gauge on the stock pressure and see what it climbs to
Is there a turbo needle on the dash
If you can, take the heat shield off and look at what turbo it is, that will tell all!
15g=T5/R/T5-R in the USA at least
: InMotion 17psi stage 2 : 19T Angle Flanged : 3 Inch Turbo Back No Muffler/Cat : IPD SRT5 Intake : HKS EBC IV : MSD Ignition + IPD Coil : HKS Type BOV : IPD Reverse Intercooler Piping Kit : More :
#3 oRange855
    ashtray gaugepod pimp
  • 2,366 posts
Posted 23 October 2009 - 10:01 PM
Theres no reason to take anything apart first off 96's were all HPT secondly if the 7th digit of the vin is a 7 its a normal turbo, if its a 8 its a R. All have 15g's in the US.
1996 855 T-5M
1984 242 GLT- The money pit 15K+ invested
Looking for -86 242's and 244's
#4 riant5
  • 25 posts
Posted 23 October 2009 - 11:09 PM
ok, so there is a boost gauge in the gauge cluster, but i know its not an r, at least im pretty sure because it doesnt have the special door seals or whatever that the Rs have, i think they have the chrome door seals right? also what do you guys think would be the most boost i should run on this engine with it being stock? i was planning on putting in boost and a/f ratio gauges anyways.
#5 riant5
  • 25 posts
Posted 24 October 2009 - 03:34 AM
anybody?
#6 BoostedBrick
  • 61 posts
Posted 24 October 2009 - 03:36 AM
Just check the VIN, that will tell you everything you need to know. Look for the 7 in the 7th spot, easy to remember haha. I think the LPT would be a 5 but not 100% sure on that.
If you install a good quality boost and AF gauge you should be able to slowly add a few pounds of boost. Just make sure you don't get too lean...or too greedy. Remember, with the quick spool of an MBC it will become much easier to bend rods, and thats no fun.
1996 850 Turbo
ST 17psi tune on a 16T Angled Flange Turbo
Silicone Hoses, MSD Coil, K&N Filter, H&R Springs, Bilstein HD
#7 riant5
  • 25 posts
Posted 24 October 2009 - 04:09 AM
hopefully bending rods wont be too much of a problem for me since everything is gonna be stock
#8 Jaxx
    Sandy Orangina
  • 9,065 posts
  • Interests:big red bricks
Posted 24 October 2009 - 05:20 AM
no LPT in 96.
edit: and yeah, you're good to run upto 1 bar. fuel cut will stop it if it's higher than that. I ran 13 or so in the burgundy... It ran a 14.9 @ 90.6, heat soaked. You'll be amazed what a big difference a few PSI is.
edit2: a quick spool from an MBC won't bend rods. Stop spreading bad info, jesus christ. Detonation causes bent rods, not high boost low rpm bullshit. @OP, you run a good octane rating and you'll be fine with the stock ECU. It knows how much fuel to give anyway, in open loop it will take care of itself.
Nadine | ME7 S70 T5 601
#9 BoostedBrick
  • 61 posts
Posted 24 October 2009 - 04:42 PM
Quote
You are correct, a quick spool is not the cause of bent rods, but it is the cause of knock, which does bend rods.
1996 850 Turbo
#10 Jaxx
    Sandy Orangina
  • 9,065 posts
Posted 24 October 2009 - 06:26 PM
Yes. I like to point this out otherwise people start assuming that more boost means too much pressure or something and then you have people walking around saying this:
Just next time, explain what you mean, it helps members, and it helps people who are searching.
#11 riant5
  • 25 posts
Posted 24 October 2009 - 08:58 PM
wow so you ran a 14.9 in an 850 with just turning the boost up to 13psi?
#12 excessive101
  • 34 posts
  • Interests:cars, guitars, snowboarding, audio engineering
Posted 24 October 2009 - 10:24 PM
not having enough fuel causes pre-detonation which will bend rods.. anything with 15psi or under the ecu should be able to compensate for without a problem.. anything beyond that.. I'd swap in some slightly bigger injectors..
one piece of advice.. before cranking up the boost.. replace your fuel filter..
#13 riant5
  • 25 posts
Posted 24 October 2009 - 11:13 PM
good advice, thank you
#14 BoostedBrick
  • 61 posts
Posted 25 October 2009 - 01:01 AM
Quote
Quote
Thats a very good point, sometimes I forget that other people can't see inside my brain haha.
Quote
LOL! Yes, and then after you shift up through 7 gears while testing your car, the floor board falls out.
1996 850 Turbo
#15 gilber33
  • 9,408 posts
  • Interests:you
Posted 25 October 2009 - 01:32 AM
not to steal the op's spot light here, but quick question.
That info applicable to all years? I carfaxed my VIN and got 2.4l n/a, 7th digit of vin is a 7, has a boost gauge, emblems, and most importantly, a turbo. Just weird.
94 850 T5M - RICA Stage III - 19T - I like boobies
PM me for "Gabe Approved" pricing quotes today!
#16 excessive101
  • 34 posts
Posted 25 October 2009 - 01:43 AM
/\ yea that happens sometimes.. just a simple mix up during the stamping process..
happened to my dad's suburban 1500 350 v8 vin said it was 2500 series with a 454..
meanwhile, enjoy the slightly cheaper insurance..
#17 gilber33
  • 9,408 posts
  • Interests:you
Posted 25 October 2009 - 01:46 AM
Work it. I'm going the enjoy the fruck out of it.
#18 Jaxx
    Sandy Orangina
  • 9,065 posts
Posted 25 October 2009 - 08:49 AM
yep. it was something like that. From the trap speed you can tell that heatsoak and motor age was a factor. many people trap a few mph quicker.
#19 riant5
  • 25 posts
Posted 25 October 2009 - 10:09 PM
nice
IPD
