Instrument Panel Lights
10 replies to this topic
#1 Ed Geraghty
Ed Geraghty
  • 57 posts
Posted 22 November 2004 - 03:25 PM
Hello,
I have been working on replacing the burnt out lights in the switches in my dash board. Does any one know if the heated seats switches are illumincated? If so, do you need to pull the console apart to get at them or do they pop out just like the switches in the dashboard?
Is the headlight switch illumination bulb easy take apart and replace? Would the procedures be similar to the other dashboard switches?
Thanks again for any help,
EdGy
1993 850 GLT 122K miles
#2 JehovArob
JehovArob
  • 1,941 posts
Posted 22 November 2004 - 04:39 PM
Yeah, the heated seat switches are supposed to be lit. They should just pop out of the top. But here's the problem: for the '93 850s, Volvo decided when they were making it to just solder the bulbs into place in the switch. So, you'll have to desolder the one in there and solder a new one in place. Personally, I plan to replace them with LEDs sometime. There's a big thing about replacing those blubs as a sticky in the cosmetics section.
As for the headlight switch bulb, if you're talking about the one that goes on once you have turned the dial to turn on the headlights, that one is easily replaceable. Just pull out the whole switch, and you'll see the little bulb holder in the back. Just pull the whole thing out, put a new bulb in, and shove the whole thing back in.
#3 Mike H. II
Mike H. II
  • 29 posts
Posted 22 November 2004 - 05:37 PM
Ed,
Generally speaking, any switch that has a little picture window of the function should be lit - including the heated seat switches. They pop straight out but sometimes not easily.
Check at the top of this forum, on a pinned thread, "user supplied knowledge" for a write-up on relighting the switches.
Mike H. II
'93 854 GLT
'03 Honda Odyssey EX
Formerly '82 244 Turbo w/M46 & '98 V70 base
#4 JehovArob
JehovArob
  • 1,941 posts
Posted 22 November 2004 - 06:03 PM
Oh yeah, it is here. I thought it was in the cosmetics section before...
#5 Guest_Guest_*
Guest_Guest_*
Posted 23 November 2004 - 02:27 PM
QUOTE(StarmanDXE @ Nov 22 2004, 06:03 PM)
Thanks for all your responses. I was able to replace two of the bulbs already using those instructiions.
Anyone have a suggestion on what to use to clean the electrical molex plugs and connectors before putting it all back together. The service manual suggests spraying antirust spray. I find the molex plugs are extremely hard to remove anything to make them go one/off more smoothly would be great.
TIA,
EdGy
#6 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 23 November 2004 - 06:57 PM
QUOTE(Guest @ Nov 23 2004, 06:27 AM)
EdGy
I'd use an electrical contact cleaner... anything that doesn't leave a residue should work.. like some brands/types of brakecleaner...
#7 Ed Geraghty
Ed Geraghty
  • 57 posts
Posted 08 December 2004 - 02:23 AM
I just pulled the dashboard dimmer switch out to replace the bulb inside and I can't seem to figure out if where the bulb is. . According to the wiring diagram, there is supposed to be a light in that switch. Does anyone know how to get at that bulb?
Thanks again for your Help,
#8 JehovArob
JehovArob
  • 1,941 posts
Posted 08 December 2004 - 03:06 AM
You've probably got to pry open the whole thing and do some stuff inside. Something I've been contemplating as I would like to put LEDs in my switches and everything.
Anyone have experience opening the dimmer switch?
#9 Ed Geraghty
Ed Geraghty
  • 57 posts
Posted 08 December 2004 - 03:27 AM
QUOTE(StarmanDXE @ Dec 8 2004, 03:06 AM)
Well I pulled off the front slider part. There doesn't seem to be any translucent part to allow light to pass thru. I would assume you could see the bulb looking into the front of the switch. I haven't been able to pull of the back part yet either. sad.gif
Edited by Ed Geraghty, 08 December 2004 - 03:27 AM.
#10 Ed Geraghty
Ed Geraghty
  • 57 posts
Posted 08 December 2004 - 05:31 AM
Just got the whole dimmer switch apart. There is no bulbs in there at all so the mystery is solved. I have a few photos of its innards .
#11 JehovArob
JehovArob
  • 1,941 posts
Posted 08 December 2004 - 05:35 AM
Really? It doesn't light up? I thought mine does. I'll have to check next time i'm in my car.
