I have a 1996 volvo 850 non turbo, I left it sitting for about 6 weeks when I was out of town. Came back and a rodent had chewed through my wiring harness. rewired the car and got it running, but i had the orange flashing arrow on the dash. Tried to drive it but it was stuck in winter mode. I heard that the pnp switch will sometimes act up in cold weather, so I replaced that, But the problem is still there. I had someone look for codes, and po745 came up which is the pressure control solenoid. So I'm wondering if that could be the problem, I do have a odbII computer and when i plug it in and erase everything, the light will go off for about 5 to 10 seconds, and the car will drive fine but it'll start flashing and then go into winter mode. I never had a problem before this so I'm pretty stumped, any help would be great , Thanks
Orange Transmission Arrow Flashing
Started by grd850, Nov 04 2009 12:34 AM
4 replies to this topic
Posted 04 November 2009 - 12:34 AM
Posted 04 November 2009 - 12:42 AM
I'm thinking by winter mode your stuck in 3rd? Think its going into limp mode is the issue...maybe not?
The wiring to the PCS i would definitely look into since it gave that code...the rat mighta blown it up or something lol...
1996 850 R - My Love, Suwanee
VS for life
VS for life
Posted 04 November 2009 - 12:53 AM
Posted 04 November 2009 - 12:55 AM
Rodents have an affliction for causing electrical problems. Where was the harness chewed? If the arrow and code were not there before the rodent damage, I have to think it's likely the problem is rodent related, double check the wiring.
98 S70 T5M
Posted 04 November 2009 - 07:37 PM
This might help you out in your wiring. I would double check all that wiring. Gotta love them rodents! Let em swim in anti-freeze!!!
*-J-*
