No Cold Start
Posted 04 November 2009 - 04:47 PM
My NA '96 Volvo 850 has not been starting during cold and/or damp weather. The vehicle will crank but will not fire up. I've done some research and many have suggested the possiblity of a bad Fuel Pump Relay. I removed the relay (#103) and jumped it with no success. I can hear the fuel pump working with the relay installed but not when it is removed with the jumper installed. What does this suggest? I've also read that it could be the Fuel Injector Relay. How can I test this relay?
Also once the vehicle sits for a while and the outside temp warms up, I have no problem starting the vehicle.
Please help!
P.S The car has about 200K on it. Ignition Wires, Spark Plugs and Distributor Cap and Rotor were replaced at 130k
Posted 05 November 2009 - 03:46 PM
Currently: '09 XC70 T6 (3k); '95 855T (128k),'84 MB 380SL (94k summers only).
Kids cars: '98 S70 T5M (130k), '98 V70 M (116K).
Prior Volvo's: '85 744 (256k), '86 245 (165k), '86 245 (195k), '88 745 (208k), '91 745 (196k), '93 965 (147k), '95 855 NA (190k), '98 XC (98k), '07 XC70 (40k).
Posted 05 November 2009 - 03:50 PM
Ian Carr - 99' Volvo S70 T5M - 86' Porsche 944 Turbo - 07' Mazda 3
True CAI, Neptunes, XC bumper, iPd25mm rear sway, short shifter, front mount, ssqv, sweet license plate mounted in the engine bay, D2's
Posted 06 November 2009 - 01:34 PM
mbsl98, on 05 November 2009 - 03:46 PM, said:
I checked the schrader valve and there is fuel being released under pressure. How can I test the ETC?
Posted 30 November 2009 - 09:00 PM
The no starting problem has started again and its definetly related to cold damp days. When I had it sitting in the garage it started no problem. After having left it outside in the cold for several days the car didn't start.
When checking fuel pressure at the shrader valve with the key in position II should there be constant fuel pressure? When I depressed the valve a minimal amount of gas is released under low pressure and then it stops. Is this normal?
Posted 06 December 2009 - 10:12 PM
My Thread
I cleaned the IAC and it didn't help BTW. I'll be swapping the ECT in the next few days, likely tomorrow evening if I can get a 7" T40 bit at HD tomorrow after work.
2006 V70 2.5T 148k
Posted 06 December 2009 - 10:22 PM
Ive had multiple battery drain issues (lights stuck on, amp wires crossed... dumb stuff) but this time I had a good 12.5 volts on the batter, really nice battery with loads of power, cranks the car 20+ times but no start..
I hear the fuel pump, but still no start... tried hitting the accel. pedal a bit but no difference.
I thought maybe the IAC is stuck because when i stopped and pulled the key out and opened the hood- (car completely off) I get this buzz coming from under the throttle body cover... (is that normal?)
I do hope there is a easy or obvious solution here- really **** tired of my car not starting... freakin put over 8 grand into it by now easily and its disappointing...
makes me want a honda lol- sometimes i think that the only reason volvos are such good cars and they run SOOOO long is because the person that has the money to buy a volvo ... has the money to fix a volvo.
*sigh*
Ill keep an eye out on this topic i suppose- really do need a fix for this though...
Posted 07 December 2009 - 01:11 AM
Quote
Seriously I think there is overwelming opinion that this is the ECT. It's a pretty cheap and easy fix too, you just need to make sure you have the ECT, it's washer, and a 7" T40 Torx bit like in the Bay13 instructions. You should also be able to do the job without draining coolant by clamping off the large hose before removing it. You might have to top off the coolant but should be no more. I'll post a followup if I get lucky, do the job tomorrow night, have an unusually cold morning on Tuesday and the car starts with no problems.
2006 V70 2.5T 148k
#14
Posted 07 December 2009 - 02:06 AM
Thanks for the help- ill keep checking back here
#15
Posted 07 December 2009 - 02:34 AM
SANTINO, on 06 November 2009 - 01:34 PM, said:
I think *think* that we can't actually tell- obviously if the fuel pump is working then you would get a spray of gas off the end of the fuel rail...
If the ect is working properly on a cold day then i would assume that spray would be MORE... however im not sure we would notice without having a fuel rail pressure checker... i think you can get one at pepboys for 15 bucks...
hate these things i cant quite diagnose...
if there is an obvious way to test the etc id love to know
Autozone
#16
Posted 07 December 2009 - 07:07 PM
Quote
ECTs are thermistors they are solid state resistive sensors that change in resistive properties as the temperature changes.
The big however:
I've thought of this before, so I took my new ECT and connected it to the electrical system but did not replace the old ECT, this way it the new one should have been feeding resistance to the computer but it was just sucking air instead of coolant (I know it doesn't actually suck). This did not work however. One possibility is that the good ECT which was in my glove box wasn't cold enough to tell the computer to feed enough fuel to make it start (the same problem that you'd have with a broken ECT).
Another trick might be to find out what the resistance of the ECT is when it's really ALL GLORY TO THE HYPNOTOAD cold (like in the freezer cold), then grab a power resistor of that value and stick it across the ECT's harness leads. Should tell the computer to run very rich, so no matter if it's warmer than "ALL GLORY TO THE HYPNOTOAD cold" the car should start, albeit running very rich. Leave it like that until the car warms up a bit then swap back to the broken ECT.
2006 V70 2.5T 148k
#17
Posted 08 December 2009 - 01:26 AM
Old pump pulling too much current, burned contact on fuel pump relay.
New pump and relay, runs like champ.
I pulled the relay cover off and cleaned the contacts then started the car to confirm.
Measured amp draw through the pump and it was way too high.
BTW it's relay marked 103 under the fuse box cover in the engine bay...
#18
Posted 08 December 2009 - 02:28 AM
#19
Posted 08 December 2009 - 03:25 AM
#20
Posted 08 December 2009 - 04:07 AM
SANTINO, on 08 December 2009 - 03:25 AM, said:
the GREY fi relay on the fan shroud... or the TPS itself. Check the wiring to that grey relay on the fan shroud!
