still looks almost standard from the outside
this is an old picture as its got factory mirrors, but everything else is still the same
the interior is a bit bare now
i've also got to make up some alloy door cards yet
i'm still working on lightening the bumper reinforcement
yes i know its a mess, but i've still got more to do in the engine bay so not spent much time on it yet
a total of 263kg (579.8pounds) removed, thanks for looking
Engine Spec:
S60R exhaust manifold
19T turbo
Forge Motorsport recirc valve blanking plate
Ferrita 3inch Stainless steel downpipe
QTP exhaust cut-off valve
polished & internally modified Volvo 960 throttle body
3inch stainless steel reverse flow intercooler pipes
3inch stainless steel intake pipe, including 3inch MAF sensor housing
Apexi AVC-R boost controller
vac hoses replaced with internally braided hoses
7mm double silicone HT leads
TWE oil catch tank
Powerflex top engine mount
Powerflew wishbone bushes
VW Vento horns
front panel & scuttle panel removed
Powerflow stainless steel exhaust back-box with twin exit (one each side)
CCR cone filter
battery moved to boot using Nolan engineering alloy battery tray
throttle wheel cover removed
spark plug cover removed
radiator under tray removed
Volvo strut brace
Volvo 302mm brake conversion
Black Diamond braided brake hoses
Volvo lowered chassis option (30mm lower)
fan bypass switch
under bonnet sound insulation removed
DRE sequential shift light
launch control (automatic with manual bypass)
full throttle gear-change
fuel injector rail cover removed
EVAP system & carbon canistor removed
bonnet hinges, springs, catches, cable & lever removed
excess wiring removed from loom (including repeator lights, aircon, cruise control, headlight wipers etc)
Interior:
Dino leather 3 spoke steering wheel (with Momo boss)
custom carbon fibre steering wheel centre
all switches moved to box unit by handbrake
gear level shortened by 1.5inches
Race-X gearknob (colour coded & chrome
Race-X Alloy pedal grips
Cobra Monaco S bucket seats (passenger side on quick release mount)
Raceland clip-in 3 point harnesses
non-turbo gauges (including higher range rev-counter)
everything else removed, including carpets, dashboard, sunroof, excess wiring etc
Exterior:
T-5R front bumper with chrome mesh grill & intercooler vents
private registration plate reading “BIG T5R” or “BIG TOSSER”
headlamp wipers removed & under headlight panels replaced
RGM headlight eyebrows
day running lights disconnected
front fog lights removed
LED sidelight bulbs
S70 washer jets
single windscreen wiper conversion
quick release bonnet pins & hinges removed
S70 fuel filler door
custom TWR pinstripe decal & window graphics
1995 spec rear lights & inner boot panel
passenger side front door handle de-locked
8 x 18 Fox R4 alloy wheels with 215/35/18 tyres
rear bumper modified for extra tailpipe
SAAB 900 rear spoiler
Perspex side windows
wheel arch linings removed
front mud guards removed
USA spec front wing badges, replacing repeator lights
Nordic design mesh bonnet grill
GP2 wing mirrors
Boot badges, hinges & shocks removed. Boot lid now secured with catches
