Looking At 1Stgen V70S...Making A Mistake?
4 replies to this topic
#1 Member
Member
  • 1 posts
Posted 07 November 2009 - 03:49 AM
As a BMW owner and longtime Volvo lover I'm thinking about making my way into one of my favorite cars, a V70. I'm looking for something cheap that I can mod as I go. When I mod a car it's clean, mostly-OE stuff. The V70 would have something like Volans, C70 Jewels, XC grille, R bumper, and a nice suspension, and other goodies. Nothing groundbreaking, no cheesy headlights. It will end up manual-swapped. Just want a fun, comfortable, fast hauler.
This is my current E34, a '95 525i. I've done just about everything to it including a manual swap.
I've read a lot on the forums about these cars. Something that keeps coming up is about '98 vs. '99-'00 and I don't know what I should do. I see that the ETM is still an issue on the later cars. But I don't know what else is different, as far as better vs. worse. I'm also looking at manual swapping and apparently the '98 is easier?
I know that I want a FWD V70, as I don't want to deal with the finnicky AWD system. Is going to FWD as simple as removing a driveshaft?
Is it a total mistake to go with a GLT? I'm really looking for a deal but not sure if 230 hp is enough after an IPD reflash. Hold out for a T5?
If you have any advice or comments let them commence! Thanks!
#2 steve s
steve s
  • PipPipPipPip
  • 3,254 posts
Posted 07 November 2009 - 08:18 AM
hey, cool, only e34 other than an m5 to have rear seat headrests :)
go with 1998 v70 t5m fwd.
it may be hard to find tho. glt is fine, much more responsive down low. i don't know if glt came in manual or not.
#3 Big Will
Big Will
  • 2,200 posts
Posted 09 November 2009 - 08:54 AM
Don't know where you are from, but if it's N. America then the GLT did not come in a manual - it was a light pressure (13G or 13T depending on the year) turbo motor. If you mod it well you can achieve well more than 230 hp but it's not the out of the box 236+ that the T5 has so it's probably worth waiting for the T5 unless you really like the characteristics of the LPT motor (I do). The T5 was also available as a manual and even though they're a bit rare, they aren't so hard to find if you look around. Less work than a manual swap.
Good luck with your search!
Me: "Yea."
#4 64pvolvo1800
64pvolvo1800
    Old Man Crew Treasurer
  • 2,062 posts
  • Interests:Volvo's & Sphynx
Posted 09 November 2009 - 11:28 AM
The ECU can be swapped out on a 98 easily. I think not so on a 99+. 99+ has Variable Valve Timing too.
98 :tup:
<img src="http://volvospeed.com/vs_forum/uploads/1163000440/gallery_15171_40_13687.jpg" border="0" class="linked-sig-image" />
<!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro-->64PVolvo1800<!--colorc--></span><!--/colorc-->
Current: 98S70T5M, 98S70M, 64 P1800S, 12 S60 T6 AWD, blk/blk/red/Saville Gray
Past: 93 850GLTM, 93 850GLTA, 90 740GLEA, 87 240GL, (2) 85 240DL, 79 242GT, 98 V70GLT,07 V70 2.5T red/red/silver/silver/silver/blk/brown/silver/titanium
#5 TyConn
TyConn
    Delta Bravo
  • 900 posts
  • Interests:Wings 'n Things
Posted 09 November 2009 - 11:04 PM
you're making a mistake unless you look ONLY at 1998, and/or ONLY at Rs
and 00+ has CVVT
1998 V70 T5 M
1994 854M Silver on Black
1998 Black on Black S70T5
1998 S70 GLT
1990 245 DL M47
...RIP at 320K
