Custom Tweeter Dash Mount
16 replies to this topic
#1 4Boys
4Boys
  • 63 posts
Posted 12 November 2009 - 04:18 PM
Thought I'd share how I mounted some aftermarket tweeters using the original dash tweeter mounts.
Attached File  DSC03620.JPG   391.44K   102 downloads
The original tweeter is kept in place by four tabs and some adhesive. Ginger coaxing and it will easily pop out.
Attached File  DSC03614.JPG   801.02K   71 downloads
For the new backing plate I used textured abs sheet $3 to $5 for a 1/8 " thick
12" x 12" sheet.
Attached File  DSC03616.JPG   311.68K   48 downloads
The old speaker outline and mounting holes are traced onto the sheet.
Attached File  DSC03619.JPG   230.81K   47 downloads
Large sheet metal sheers make easy work of cutting outline out. This was followed by a sanding on a oscillating belt sander to finalize the dimensions .
Attached File  DSC03627.JPG   314.82K   53 downloads
Once the burrs from sanding were removed the piece was taken to a drill press. A 5/16" drill was used for the four corner mounting holes and a 1 3/4" dia. hole saw specific to the tweeter.
Attached File  DSC03622.JPG   563.4K   92 downloads
Finished backing plate after burrs removed.
Attached File  DSC03623.JPG   814.32K   158 downloads
Backing plate just snaps into mounting bracket ready for tweeter .
Attached File  DSC03624.JPG   562.29K   199 downloads
The finished product. :D
Edit:
Did the rears. Same procedure as before minus drilling the four corner tab holes.
Make sure the mounting hole for the tweeter is dead center in the mounting plate or your tweeter may not fit. Do this by inserting it into the mounting bracket . Then scribe around the original mounting hole where the old tweeter was and find it's center I found it to be a 1" radius. As you can see mine was a very close fit.
Attached File  DSC03630.JPG   817.5K   144 downloads
96 855 auto. , 16T, BSR 17 psi tune, Corvette LS1 white injectors, rising rate fuel reg., Walboro fuel pump, R mani., OBX exhaust , metal cat., MSD. coil, custom Accel 8mm wires, Baja Scorpion CDI, IPD intake, A/C Delco tcv,J-pipe intake, IPD springs ands sways, Koni adj., ipd strut bar, IPD CBV. Samco intercooler hoses, Poly engine torqe, fire wall and tranny bushings.
#2 Gage
Gage
    Che's Favorite
  • 2,688 posts
  • Interests:Sleeping , Driving And Sleeping
Posted 12 November 2009 - 04:25 PM
Nice Work !!!!!!!
-Pat-
'99 S70 AWD
RIP-Tom, '94 855 Turbo 5spd BUILT NOT BOUGHT
#3 Dave 54
Dave 54
    Old Man Crew Pledge
  • 4,902 posts
Posted 12 November 2009 - 05:25 PM
Very nice!!! :tup: :tup:
Very well may do this myself, i've never been one to hack into my door panels for a set of components. Grabbing a spair set at the yard to play with.
Any issue's with clearance of the stock grill?
DAVE
96' 850R
#4 4Boys
4Boys
  • 63 posts
Posted 12 November 2009 - 05:55 PM
View PostGage, on 12 November 2009 - 04:25 PM, said:
Nice Work !!!!!!!
Thanks, overall fairly quick and easy to do.
#5 4Boys
4Boys
  • 63 posts
Posted 12 November 2009 - 06:06 PM
Plenty of room.
Attached File  DSC03629.JPG   760.01K   86 downloadsAttached File  DSC03628.JPG   783.28K   82 downloads
#6 Mossback
Mossback
    Old Man Crew Sgt at Arms
  • 1,632 posts
  • Interests:Volvos
    SciFi
    My kids
    Staying married (25 years)
Posted 13 November 2009 - 04:46 PM
I really like this. I've never been impressed by the OEM system's high end and also don't believe in cutting up the doors/dash. This might be just the improvement to try.
01 C70M
Garage
1 of 603
#7 beadgc23
beadgc23
  • 500 posts
Posted 13 November 2009 - 05:04 PM
First kudos - I started with something similar but using much less professional techniques (artboard and an x-acto knife...) However bouncing treble off the windshield through those comb-filter grilles gave me a very ill-defined front stage. About a month ago I moved my boston tweeters to the door sailpanels, using the angled mounts that came with them (I'll take photos tonight) and stashed the xovers in the doors. The front stage improved 200%. It's well worth experimenting with if you have appropriate mounts, and sail panels are easy to source if you need to return them to stock.
Of course, I had to complicate things when the center channel dash arrived which also bounces treble off the windshield - still trying to work this one out!
1998 V70 T5 Bilstein TC's & Kilen springs, Boston & Dolby audio. IPD Stage 1 tune & HD's, 3 HID's
#8 4Boys
4Boys
  • 63 posts
Posted 13 November 2009 - 06:00 PM
Agreed. Mounted them so they could pivot and experiment with. Ideally they should be mounted closer to the midrange for impoved imaging. Def. want to check out your pics.
#9 nedskifta
nedskifta
  • 19 posts
Posted 16 November 2009 - 01:54 AM
wow, I'm gonna go do this right now, really elegant idea!
#10 beadgc23
beadgc23
  • 500 posts
Posted 16 November 2009 - 03:12 PM
Finally got around to it - phone pix I'm afraid...
Posted ImagePosted Image
For shame the dust! Left is pointed at the head of the passenger, right at the driver. Stereo image is very stable across the hood, center channel adds center front midbass but blurs the image slightly so I plan to add a boston tweeter to it.
The tweeter mounts are attached with two bolts + locknuts & springs. They hold solid but can be rotated at need. Cables run down with the mirror connections to the xover which is plastic bagged and foam mounted behind that plastic access hatch at the bottom of the door.
NB These are the only visibly non-stock audio items in the car, other than the iPhone cable and the sub which is covered in the trunk.
I did the d pillar tweeters with a pair of large diaphragm Boston 8ohm hifi tweeters, had to epoxy them to some spare mounts. Great depth for the pro logic setup without calling attention to themselves.
#11 Dave 54
Dave 54
    Old Man Crew Pledge
  • 4,902 posts
Posted 16 November 2009 - 04:24 PM
Very nice, but i'm not sure that would work in the 850's, appears it would either hit the dash when closing the door or image right into it, our dashes are alittle taller and vertical on the driver's side.
DAVE
96' 850R
#12 dimasp
dimasp
  • 4 posts
Posted 09 January 2011 - 04:39 PM
12" x 12" sheet.
Edit:
#13 dimasp
dimasp
  • 4 posts
Posted 09 January 2011 - 04:49 PM
Hi! I'm new to this page, I own a '95 850 GLT, and I just read about your work and I think is great and well done. If it's possible can you tell me what model or size the tweeters are?
DimasP
#14 beewerks
beewerks
  • 421 posts
  • Interests:Beekeeping (family business), Computers and IT, photography and cycling.
    Wrenching on often broken Volvo's
Posted 10 January 2011 - 03:38 AM
Very nice. I did the same thing with a pair of Focal tweeters a while ago. I just chopped out the already blown stock tweeters and dremeled out the back of the mounting plate.
'98 V70 AWD being converted to T5
'94 850 Wagon non-turbo--SOLD
#15 Serge
Serge
    Level 6 Senior Member
  • 10,667 posts
Posted 11 January 2011 - 09:14 PM
How does it sound? Better I'm guessing.
Serge - 95 850 T5
#16 nautic70
nautic70
  • 31 posts
Posted 13 February 2011 - 07:39 AM
The install part looks very slick but how is the staging with the tweets bouncing of the windshield?
1998 Volvo S70 N/A slushbox the lowest of the low.
1998 Volvo XC70 I has a wagon now
#17 Vagabond
Vagabond
  • 922 posts
Posted 13 March 2011 - 06:06 AM
Sounds fine.
Did the same a few months ago.
1994 850 NA 189,XXX mi. Coming Soon: Mo Flow...
The Build
http://volvospeed.co...ou-get-for-200/
Eclipse AVN5435 6.5 inch Navigation For Sale...
