Replaced at purchase - axles, control arms, rotors, all engine mounts
This summer - struts, springs, spring seats, end links, inner & outer tie rods (in order), alignments along the way. Everything is torqued to spec and seems good. All parts are Volvo, IPD, Bilstein or Kilen (springs)
What I'm experiencing now is a gentle clunk, apparently from under the center of the car level with my feet, most apparent in stop & go traffic when I apply the brakes extra firmly. It's more felt than heard, and is definitely not localized at either wheel, it's like the whole suspension is making the sound, and again its quite soft & gentle, not a hard "clonk". It doesn't happen when I brake in reverse. No other noises when turning, accelerating or highway braking.
It appeared just after I installed the IPD HD end links. Sway bar is stock (it's about all that's left that is...
Anyone had something similar or have a suggestion as to where I should look next?
