Throttle Cable Ftl
  • You cannot reply to this topic
9 replies to this topic
#1 The Emperor
  • 151 posts
Posted 13 November 2009 - 03:11 AM
98 S70 T5M 198k
So merging onto I-4, I put the car into 5th gear and idle went the tach. FML
Opened up the hood, saw the throttle cable hanging off the wheel, pulled the rest of the cable out from the sleeve and it was nice and snapped :(
My question is, has this ever happened to anyone else, and where can I find a throttle cable cheap (please not from the stealership if possible)
Also, it looks like a pretty straightforward install... Anyone care to shed some light on things I'd want to be aware of when doing it?
As always, I appreciate your help
-Dave
2006 Passat 3.6 ---- New Ride
1998 S70 T5M 206k ---- GONE
#2 Chilled Man
    MILFSPEED
  • 29,898 posts
  • Gender:Not Telling
Posted 13 November 2009 - 03:21 AM
actually pretty cheap from the dealer new
#3 FCP Groton
  • 1,838 posts
Posted 13 November 2009 - 03:30 PM
And even cheaper from a junk yard. We may also sell them but I can't find it one our website at the moment. You can always give use a call at 1-877-634-0063.
Oh, and I had this happen to me on my old 240 and I also had it happen to me on my motorcycle back in the day so it does happen.
Andrew Owendoff
#4 Mesoam
  • 18,303 posts
Posted 13 November 2009 - 04:16 PM
no, throttle cables FTW, drive by wire FTL, not checking your 200K mile car for a fraying wire FTL
and no its not common
96 854 R, CLICK ME
The Jeep
#5 T-5Bandit
  • 1,826 posts
  • Crew:SCC
Posted 13 November 2009 - 04:27 PM
Part number is 9157601. It's only @$35 - $40 at the dealership and it's a dealership part only.
Install takes no more than 15 mins.
- Disconnect at pedal and throttle body.
- unplug sensor at firewall.
- pull/pry gromet at firewall.
- install new cable in reverse.
John
1998 V70 T5
Chrome 19" Niche Rhine Wheels
#6 Big Will
  • 2,174 posts
Posted 14 November 2009 - 10:56 AM
There are 2 different cables: 1 for automatic which is listed above and this one for the manuals: 9157600
Me: "Yea."
#7 Hanks
  • 3,272 posts
Posted 14 November 2009 - 10:09 PM
interesting.... anyone know the differences?
#8 sea-xc
  • 52 posts
Posted 14 November 2009 - 10:44 PM
I got an auto one from FCP recently. Autos have a kickdown switch integrated into it. I was curious why it was different from the manual as well. When I installed mine, I figured it out. Actually it calls out the switch in the instructions in the Hayes manual.
I had to replace mine since the throttle was sticky. The final straw was when it stuck at full throttle after going up a hill. Prior to that it would stick at light loads and a blip of the gas would fix it.
98 Coral V70awd 201k, 16t, t5ecu, Ipd tcv, cbv, silicone hoses, Yakima racks.
04 Suburban 126k, gear and kid hauler
07 Mazda6s 5spd hatchback current work daily driver
#9 Big Will
  • 2,174 posts
Posted 14 November 2009 - 11:41 PM
Joe, who hasn't posted on here in a while and converted his R into an M56 FWD car last year changed out his cable to the proper manual one and said it significantly improved throttle feel (pedal feel) and control. I trust his opinion on this so it is probably a worthwhile "upgrade" for manual swappers.
Certainly if you have a manual to start out with you might as well use the proper cable.
Me: "Yea."
#10 lcc014
  • 731 posts
Posted 15 November 2009 - 03:47 AM
Good write up, however it would be excellent if you could provide some photos to show the : disconnect at pedal and throttle body; sensor at firewall and the grommet at firewall.
Many thanks.
Ching-Ho Cheng
1995 855 NA: Bilstien Touring Strut & Shocks, Volvo Protective Grill, K&N Filter, E-Code Lens, ClearCorner Light, Alpine CD-Changer, AutoDim RearView Mirror, 6000K HID, Tranny Cooler
2005 530i: PPP, CWP, Nav, Xeon, Rear SunShade, Steptronics, Blue Light Door Sills, Wide Angle Driver Side Mirror, M5 iDrive Knob, White LED License Plate Light
IPD
