Abs Module
8 replies to this topic
#1 Spanky
Spanky
    Has a boner for Adam's Dad
  • 1,534 posts
Posted 14 November 2009 - 10:03 PM
(X70)Are they glued? snap together?? Trying to open one up and don't want to crack her.
Thnx
Contact me for turbos, turbo parts and rebuild kits
#2 Gizmo
Gizmo
  • 152 posts
Posted 14 November 2009 - 10:54 PM
If its anything like the 850 box, I had to dremel mine open... The fix is pretty straight forward once you're in there, if you're handy with a soldering iron, but I really recommend a high powered jewler's loop to examine the solder joints... failed joints are hard to see, and I ended up having to go back in again 10k later.
-Evan
Black 1996 854T Bils, Samcos, homebuilt MBC, R Manifold, TD04HL-16T, backcut valves, and a ridiculous amount of luck.
#3 Zappo
Zappo
    The One Upper
  • 15,531 posts
Posted 16 November 2009 - 05:42 PM
Where did you cut?
#4 Ipd
Ipd
    Mr. IPD
  • Validating
  • 1,562 posts
  • Gender:Not Telling
Posted 16 November 2009 - 05:44 PM
anhydrous alcohol and a small flat blade screwdriver is all I use.
Ohh and some patience... :lol:
#5 Zappo
Zappo
    The One Upper
  • 15,531 posts
Posted 16 November 2009 - 05:53 PM
Ohh and some patience... Posted Image
So it is glued?
Is it the black stuff that crumbles as you dig it out?
#6 Ipd
Ipd
    Mr. IPD
  • Validating
  • 1,562 posts
Posted 16 November 2009 - 07:28 PM
Correct. Some light solvent will turn the adhesive into something about the consistency of jelly and give you about 15 minutes of a work time window.
#7 Zappo
Zappo
    The One Upper
  • 15,531 posts
Posted 16 November 2009 - 07:36 PM
Good to know. Gives me something to work on tonight. :)
#8 Gizmo
Gizmo
  • 152 posts
Posted 17 November 2009 - 05:19 AM
Not like the 850 box then, at least not like mine. I had to dremel around the seem, as it was almost... friction fitted. Good to know.
-Evan
#9 Spanky
Spanky
  • 1,534 posts
Posted 20 November 2009 - 03:10 AM
Thanks Lucky.
I thought this post was all but dead :lol: :lol:.
