Gas Pedal Hard To Push
4 replies to this topic
#1 AaronD81
  • 872 posts
Posted 14 November 2009 - 10:39 PM
I've been living with it, but it's getting annoying. My old S70's pedal was much easier to push, is there any way to relieve some of the pressure on the throttle body spring? When I detached the throttle cable the pedal was really easy to push so I think it's just that the spring on the throttle body is really tight, seems much tighter than necessary to close the throttle body.
98 V70 T5
#2 bergmjs
  • 1,845 posts
Posted 14 November 2009 - 11:05 PM
Make sure the throttle linkages all glide smoothly and its not just a seized bearing in there. Take the throttle body cover off and turn it the linkage with your hand and see if it feels rough or not; might just need some lube. Also might want to make sure gunk didnt somehow get in the cable housing.
'95 854 T5M 175k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue
#3 volvotool
  • 323 posts
Posted 14 November 2009 - 11:09 PM
I've got the same car. You might need to replace the throttle cable. They do corrode with age up here in the northeast.
1998 V70T5 - 2010 VW GTI - 1989 VW Cabriolet
2000 V70R - Gone to a new home...
#4 MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 15 November 2009 - 12:36 AM
Hey Aaron,
you sure it's not just a crudded up throttle housing?
still have your old Titans BTW
"SMOKE TROUT NOT CRACK"
#5 AaronD81
  • 872 posts
Posted 15 November 2009 - 08:50 PM
Throttle cable seems fine, when I took it off the throttle body it didn't seem to be sticky. Throttle body also seems to operate smoothly, it just takes a lot of pressure to open it.
View PostMrWinkey, on 15 November 2009 - 12:36 AM, said:
Hey Aaron,
If you ever want to sell them let me know, as you can see from my signature I wish I still had them.
98 V70 T5
IPD
