P0171 & Weak Turbo
Posted 14 November 2009 - 11:44 PM
Quick search here seems to lead to a MAF, however, the MAF was already replaced only 43K mi/5 yrs ago. Could the MAF be on it's way out again this soon (was a factory replacement in Dec 04)? If not the MAF, any other suspects to check before I drop the change on a new MAF?
thx!
`96 855 Turbo 183K
Posted 14 November 2009 - 11:49 PM
thx!
you could try cleaning the maf, also could relate to a vacuum leak, may want to check the elbow on the side of the intake manifold, that's usually with a p0172 code though.
Posted 15 November 2009 - 12:34 AM
Check your intake elbow as stated then MAF
Posted 15 November 2009 - 12:54 AM
Let me know if it could be anything else. Low boost seems really like an odd result...
BTW. Car is a `96 855T, 183K.
`96 855 Turbo 183K
Posted 16 November 2009 - 02:22 PM
If not, any other ideas as to why I'm getting such limited boost? All vac & boost hoses are tight and connected properly (checked that before), no CEL.
thanks
`96 855 Turbo 183K
Posted 16 November 2009 - 03:02 PM
check your turbo wastegate, make sure it's sealing properly.
If it's fine, unplug your wastegate actuator's vac line and take it easy, just see if you can boost more than 2-3psi. If you can't, then you should look at wastegate preload and then intercooler hoses.
Nadine | ME7 S70 T5 601
Posted 16 November 2009 - 05:53 PM
Are you running all original rubber vacuum lines? Original intercooler hoses? Try and trace all vacuum lines around the engine bay. Follow the one coming off the turbo wastegate and go from there. And note that the elbow Winkey referenced is part of the PCV system, not the turbo system. There is a picture somewhere around here (Bay13?) of where it is located.
86 Kawasaki Gpz900R Ninja
Posted 17 November 2009 - 01:03 AM
FCP Groton, on 17 November 2009 - 12:42 AM, said:
Thanks much for the wastegate tips--on my way home from work today, I disconnected the vacuum line to the wastegate; no boost pressure difference whatsoever! (idle's @ -15 to -17, boosts to +3-4). Dark now, so going to check for that gap tommorrow. Interstingly, I've had odd trouble with this wategate since I've owned the car; seemed to fix it a couple years' ago by tightening the wategate down, now only to have the problem return and be more pronounced. FWIW...when I connect a hose to the wastegate and blow in it(just lung pressure), the lever does push outward.
Vacuum elbow on the intake side is tight; replaced all the vacuum hoses 4-5 years ago; they're still good.
`96 855 Turbo 183K
Posted 18 November 2009 - 05:21 AM
Is is possible for a code to limit boost without throwing a CEL? No codes for a while now detectable by the OBDII scanner. Kind of sounds like I may be having the same problem at Autotechnica in:http://volvospeed.com/vs_forum/index.php/topic/30669-for-those-with-the-elusive-%26quot%3Bboost-leak%26quot%3B/. However, my OBDII scanner doesn't have a "reset the computer" option...just clear codes...
Can a turbo just lose ability to boost with age without actually failing? (didn't think so...but...)
thanks....
`96 855 Turbo 183K
Posted 18 November 2009 - 05:42 AM
thanks....
Well... if I've learned anything about these cars... it's that anything is possible!!
However, I am with many that have previously stated you're experiencing a (probably severe) boost/vacuum leak.
One other thing to consider is that the stock intercooler soft pipe sections can fail in a different manner. Check to see if they collapse. It could be choking your air supply. Just a thought.
Your car's behavior sounds like my XC when it ripped the underside of the rubber intercooler joint at the throttle body itself.
Good luck!!
98 V70 R AWD - M66 - 2.5T
91 244 NA - M47
98 V70 XC AWD - 218K 96 960 RWD - 226K
Posted 19 November 2009 - 01:14 AM
Good luck!!
Well...thanks much for the tip! That's exactly what happened to mine--a couple of the pieces of soft pipe compressed a little bit when I added some throttle. Took a hard feel at the underside of the throttle body joint and, sure enough, huge tear. This piece was also completely rotted with deposits on the inside. Additionally, a careful inspection found a few other holes in that same piece which (I think) had been there for a long time (maybe even as long as I'd owned the car, 5 years). Ordered all new hoses from IPD (figured I should replace them all) for around $80. Meantime, duct taped the tears; not perfect but am boosting much better than I ever have before--solid 10psi with jumps over that.
Can't wait until the new hoses get here. Thanks much for the assist!
`96 855 Turbo 183K
Posted 19 November 2009 - 01:46 AM
Wow... I'm having similar problems with my s70... p0171 code comes and goes, low boost (measured by seat of the pants), etc. I'll take a look at it tomorrow. What is the best way to measure the actual boost on the turbo?
1998 S70 GLT, 225K miles
Auto Tranny
#14
Posted 19 November 2009 - 04:14 AM
clarkerussell, on 19 November 2009 - 01:46 AM, said:
I'm guessing the `98 S70s are setup same as the 850s (somebody correct me if I'm wrong)--suspect the `99+ -70s are different. Near the throttle body is a black plastic vacuum tree. Mine has the no-numbers boost gauge attached to it, so while I had the gauge in the dash, it didn't tell me anything. Purchased a boost pressure gauge from AutoZone and connected it to an empty port on the tree; ran the line inside the car while I was driving.
Am now boosting an average of 10-12 psi; before I couldn't boost over 3psi.
`96 855 Turbo 183K
#15
Posted 04 December 2009 - 01:34 AM
Drop the wastegate control hose off the BCS and go for a drive...if the pig spools up like a drunken sailor in a Hong Kong port then the mechanical end of the turbo is fine. If it's still a stone then you have a fault on the electricial side.... IN most cases ...The 1171 is a result of your positive pressure spittin' out the end of the intake causing the fuel trim to go haywire as the ECM sees it.
Does that make sense?
