1998 V70 Vibration On Turns
5 replies to this topic
#1 davev70
davev70
  • 1 posts
Posted 23 November 2004 - 09:26 PM
I own a 1998 V70 AWD with 132K miles. For the last year, when turning either left or right (90 degree turns), I often (not always) feel a vibration in the steering wheel. Similiar to the rumble strips on the side of the road. Like a shimmy... More noticable when accelerating.
It has been to two indy mechanics. And they have checked:
Brakes
CV joints
Drive Axles
Drive Shaft
Front End
Tires
Struts
Motor mounts (weak)
Wheel bearings
Found nothing wrong.
An alignment shop also looked at it, and couldn't find anything wrong.
Tires have been replaced and rotated/balanced with no effect on the problem.
Any ideas? I hate to just start replacing parts.
#2 whilst
whilst
  • 99 posts
Posted 24 November 2004 - 02:48 AM
Sounds like my quattro Audis do all the time. From new! Normal for them.
Does it only do it at low speeds? If your turning 90 degrees either way,I hope it's slow.
Are you holding wheel against steering stops while turning?
P.Steer vibes,maybe?
Your "weak" mounts could have something to do w/it.
HTH. Jeff.
'95 854T 197K+, '98 S70 base 5spd. 163K, '99 Audi A6 quattro 109K, '69 Yamaha DS6C,1973 Honda CL 350 , 1950 Roadmaster balloon tyre cruiser.
#3 Guest_Guest_*
Guest_Guest_*
Posted 24 November 2004 - 03:30 PM
Yes, it's a low speeds while turning corners.
No, it's not against the steering stops.
#4 Guest_Guest_scphelps1_*_*
Posted 06 December 2004 - 10:26 PM
My '98 V70 AWD is doing the same exact thing. When at slow speeds going around tight turns there is an audible/physical vibration. I have had the tires rotated religiously and was hoping somebody might know what is causing this problem. It certainly doesn't appear to be normal. Is it the ABS trying to correct wheel speed differences around tight corners? Anyone???
#5 scphelps1
scphelps1
  • 7 posts
Posted 06 December 2004 - 10:27 PM
Sorry; I wasn't logged in. . .
#6 XC Owner
XC Owner
  • 80 posts
Posted 07 December 2004 - 05:40 PM
Try turning off ABS/TRACS to see if it makes any difference.
Eric
98XC
210000km
