Aftermarket Speakers
12 replies to this topic
#1 T5Manual850
T5Manual850
  • 170 posts
Posted 17 November 2009 - 02:48 AM
I have a 95 turbo with sc-811 premium HU with 6disc changer in the back.....
can I install aftermarket components in the front doors and run them off the stock headunit? The components are 4 ohms.
I will be disabling the stock tweeter if that means anything.
850T
IPD Stage III + Meth/WI MT ----- 18T angled ----- 350cc white injectors ----- s60R manifold ----- 3" OBX angled dp ----- Magnaflow HFC ----- 3" Magnaflow exhaust ----- FMIC ----- 3" open element CAI ----- 2.75" Sconeman pipe ----- 150psi 250cc Meth/WI ----- MSD Blaster SS ----- Kingsborne 8.5mm spark wires ----- Forge BOV ----- Greddy Profec B spec II EBC ----- AEM Uego Wideband ----- m56H manual ----- R clutch ----- Koni Yellow Struts/shocks ----- IPD 1.75" springs ----- IPD 25mm/22mm sway bars ----- HD endinks ----- OBX v2 Strut bar ----- 302mm BBK ----- stainless lines ----- Knocksense ----- ADR RS Mase 17"
#2 ryan850-t5
ryan850-t5
  • 1,106 posts
Posted 17 November 2009 - 08:01 AM
I think the stock speakers are 8ohm so in theory a 4ohm speaker should be fine.
Ryan
'97 854 T5
Garage
#3 MyCarIsRed
MyCarIsRed
  • 1,526 posts
Posted 17 November 2009 - 12:33 PM
The tweeters in the dash and the speakers in the door have seperate amp channels, The front doors are 4ohm, so you can replace them with components as you like and still keep proper load on the HU. You don't have to remove the front dash tweeters, but they likely will sound like crap compared to new components. odds are pretty good the magnets aren't there anymore ;)
the rear door speakers are 8ohm because they're in parallel with the rear d-pillar speakers, each rear channel still shows 4ohms to the HU.
#4 MyCarIsRed
MyCarIsRed
  • 1,526 posts
Posted 17 November 2009 - 12:42 PM
[quote name='ryan850-t5' date='17 November 2009 - 03:01 AM' timestamp='1258444914' post='1680412']
[/quote}
eh no. It won't be fine... it may work, but long-term you're causing damage unless the amp is rated for the resistance you're running. Running an amp outside spec can be very bad, just ask the folks who ran Phase (flame) linears in the 70s...
#5 ryan850-t5
ryan850-t5
  • 1,106 posts
Posted 17 November 2009 - 06:14 PM
[quote name='MyCarIsRed' date='17 November 2009 - 04:42 AM' timestamp='1258461762' post='1680432']
[/quote}
[/quote]
Good to know.
So the volvo amps are rated at 8ohm?
Ryan
'97 854 T5
Garage
#6 MyCarIsRed
MyCarIsRed
  • 1,526 posts
Posted 17 November 2009 - 06:45 PM
Good to know.
4ohm, the rears run in parallel. 2 8ohms in parallel: (8x8)/(8+8) = 4ohms
#7 ryan850-t5
ryan850-t5
  • 1,106 posts
Posted 17 November 2009 - 09:19 PM
ok, so just replacing the rear deck speakers with 4ohm speakers would be bad, correct?
Ryan
'97 854 T5
Garage
#8 T5Manual850
T5Manual850
  • 170 posts
Posted 18 November 2009 - 12:39 AM
as far as I have been researching, it seems like the HU is just a standard 4ohm headunit and it's just the speaker arrangement that is causing confusion. They wire the rears in parallel together to achieve a 4 ohm load... So a 4 ohm speaker in the rear deck with the rear door speakers disabled will show a 4 ohm load, but not when hooked in parallel :)
I figured out what I'm gonna do with mine, like my old car audio setups I'm gonna yank out all the rear deck and door speakers and run a-la 2 channel via front speakers with a single 10" in the back.
850T
#9 ryan850-t5
ryan850-t5
  • 1,106 posts
Posted 18 November 2009 - 01:16 AM
so no rear speakers at all, just the front components correct? I like that idea...
When I bring my 4 channel amp down from norcal ill hook that up to my front components and im gonna get some midbass drivers for the rear doors and unhook the rear deck speakers.
Ryan
'97 854 T5
Garage
#10 T5Manual850
T5Manual850
  • 170 posts
Posted 18 November 2009 - 01:32 AM
actually put some midbass in the rear deck and remove the door speakers.
I think your headunit allows you to crossover your rear speakers...try to cut the frequencies above like 60hz from the rear and see how it does for midbass
850T
#11 ryan850-t5
ryan850-t5
  • 1,106 posts
Posted 18 November 2009 - 05:27 AM
the rear deck is not very good for a speaker enclosure plus being so close to the subs the midbass will get distorted. plus i want the midbass right behind me and ive deadened the doors pretty good.
Ryan
'97 854 T5
Garage
#12 T5Manual850
T5Manual850
  • 170 posts
Posted 18 November 2009 - 06:33 AM
what kind of drivers are you looking into getting
850T
#13 ryan850-t5
ryan850-t5
  • 1,106 posts
Posted 18 November 2009 - 08:07 PM
Peerless SLS
Ryan
'97 854 T5
Garage
