How Soon Till Bevel Gear Fail?
  • You cannot reply to this topic
8 replies to this topic
#1 Ice D
  • 10 posts
Posted 18 November 2009 - 09:40 PM
I just notice gear oil in the driveway I assume it's coming from the bevel gear seal leaking.
How soon could the gear fail? Do I have time to change the oil?
I have noticed whining and howling noise off and on. Mostly during cold weather.
#2 mdlimy
  • 2,776 posts
  • Interests:Beer, volvos, boost <3
Posted 18 November 2009 - 09:51 PM
why would you assume?
crawl under there with a flash light.
no one will be able to tell you how long it has left before it fails, we dont know how much oil is in it, how many miles it has, shit we dont even know what car it is.
information buddy, information.
Robbie
VEMS V3 w/Cop-04 2.5t w/90mm crank-v70R interior-MBZ Alphards
My build Thread
#3 Ice D
  • 10 posts
Posted 18 November 2009 - 10:08 PM
Wow, I guess I'm tired.
It's a 2000 v70xc with 160,000.
My wife just took the car. And I noticed a few drips where she has been parking this past week.
What else leaks gear oil?
#4 Pauloil
  • 503 posts
Posted 19 November 2009 - 01:39 AM
either put up on stands or ramps to check level yourself and see where leak is, or take it in.
the seals can be replaced, about $500, or less at an Indy mech.
1995 850 glt rattling down the road at 157K
99 V70XC 120K
#5 Guest_Ice D_*
Posted 19 November 2009 - 02:34 AM
These must be dealer parts only.
Has any one found a rightup for this?
This seems like quite a common problem and an expensive fix to replace the whole thing.
#6 mdlimy
  • 2,776 posts
Posted 19 November 2009 - 06:37 AM
are you good with a wrench? its not too bad of a job, pull both front axles, unbolt the driveshaft and then there are like 5 14mm bolts holding it to the tranny.
Robbie
My build Thread
#7 1998C70T5
  • 200 posts
  • Interests:volvos, carbon fiber
Posted 19 November 2009 - 06:55 AM
i had my bevel gear box out 4 times at the shop before one of the mechanics had a eureka moment. it was a 15 dollar vent that leaked.
#8 Big Will
  • 2,174 posts
Posted 19 November 2009 - 12:12 PM
Different things can leak on the angle gear.
There are a number of seals on it: The left side where the coupler mates to it, the right side where the driveshaft passes through (2 seals and an o-ring in there) and often it is the o-ring which is leaking. Unfortunately, in order to replace that, you need a Volvo special tool and it needs to be done right or else the gear will have a very short life afterwards. There are also a couple of seals on the back where the prop shaft mates up. It's about 65 dollars worth of seals (100 if you replace the little sleeve in the back), + 10 dollars to get the updated vent for the weep hole, and then the dealer usually charges 300-400 dollars for the work to replace the seals.
In addition, the casing itself often leaks. The fix for this is to crack it open, and use a Volvo sealant. The dealer usually charges 500 or 600 for this re-sealing although maybe one of the techs would be nice and would re-seal it for you after hours for very little if you pull the gear yourself and re-install it yourself.
Hope this helps.
--Will
Me: "Yea."
#9 Ice D
  • 10 posts
Posted 19 November 2009 - 10:44 PM
Thanks, a lot of good info for me to think about.
IPD
