Uh Ohh Bottomed Out Hard
10 replies to this topic
#1 cr854r
cr854r
  • 898 posts
Posted 30 November 2009 - 04:25 AM
well i was driven on the Michigan interstate system (it sucks) an i hit one hell of a bump, i think i bottomed out, but when i did this i saw all of my needles on my gauge cluster drop, an than come back up, but none of the lights died... what couldve happened... should i be concerned?
Projekt R
-Megasquirt
, 18t, 3in turbo back, kw v2 coilovers, M56H, fmic, 16 point roll cage, corbeau seat/harness, gutted to hell, *solid bushings, *F/R sways, walbro 255, 450cc injectors, NA cams, willwood brakes, port/polished head, *rsi rods, *R mani, adjustable control arms, adjustable strut top mounts, adjustable sway bar links... etc etc
#2 v4lve
v4lve
  • 1,488 posts
Posted 30 November 2009 - 05:13 AM
Did you look the car over? Anything act weird afterwards?
#3 johnloves850's
johnloves850's
  • 2,472 posts
Posted 30 November 2009 - 05:33 AM
Yea, this has happened to me before, and to most of my buddies with e46's.
You bottomed out, the needles dropped but the lights stayed on.
Since your car did not loose power from the battery, the lights did NOT turn off.
It shouldn't be a huge deal.
Just get under there and see if you have any scratches on things like rear spring perches, and control arms, subframe, et cetera, that will tell you where to look for broken things.
1996 855 n/a.
#4 Falcone
Falcone
    Pvt. Douche Nozzle
  • 1,329 posts
Posted 30 November 2009 - 03:31 PM
If you didn't crack the oil pan, your good. I'm on my third one now.
K-Town Brick Militia______________94 854 The BBQ_________________97 Pewter T5 teh dd
I was us up all night with a rusty hammer trying to build a fence around these magic beans my dreams have gathered
#5 Dave 54
Dave 54
    Old Man Crew Pledge
  • 4,905 posts
Posted 30 November 2009 - 04:20 PM
Sounds like someone should be investing in a skid plate :rolleyes: .
DAVE
96' 850R
#6 FCP Groton
FCP Groton
  • 1,838 posts
Posted 30 November 2009 - 05:24 PM
+1 on the skid plate.
Your more then likely fine. I had the wheel of my 850 fall off when I was doing 40 MPH and the only damage was to the fender. I got lucky I think.
Andrew Owendoff
#7 JordanW
JordanW
  • 415 posts
Posted 30 November 2009 - 05:49 PM
HOW does that happen? Something break, or what?
*-J-*
#8 yangotang
yangotang
    yangbang!
  • 6,900 posts
Posted 30 November 2009 - 05:51 PM
Didn't tighten your lug bolts?
Alex
2013 C30 T5 R-Design - Rebel Blue - Polestar Tuned
Old/Parting: '98 V70R AWD FWD - M56L - 19T - TT - RICA - 17" Team Dynamics Motorsport - Pro Race 1.2 - 18" Pegs - CJ Porsche 993TT BBK - CarPc - Parts For Sale - Click Me!
#9 Matty Moo
Matty Moo
  • 1,941 posts
Posted 01 December 2009 - 04:51 AM
I've thought about lowering my car, and would like to, but the roads here suck ass. All it takes is one of those big dips coming out of a construction zone to destroy everything. It's bad enough in a car with stock suspension.
#10 steve s
steve s
  • PipPipPipPip
  • 3,255 posts
Posted 01 December 2009 - 05:11 AM
dealer didn't tighten the bolts and the steering started to shake when i was doing 65.. thank goodness i pulled over.
#11 CO.T5M
CO.T5M
  • 1,431 posts
Posted 01 December 2009 - 05:13 AM
he is far lower than the normal lowering springs will take you. look at some of his pictures i think he has about 2 inches or so clearance.
