Wilwood Bbk Review
31 replies to this topic
#1 volvoluvin
volvoluvin
  • 669 posts
Posted 01 December 2009 - 04:47 AM
Finally got around to installing the Wilwood BBK kit on my 95 T5-R.
Some more pictures, late night, dark out, dirty, but you still get the idea.
Also did stainless steel lines at the same time.
Fitment and install:
Great and super easy. Hardest part of course was removing the old brake lines... :angry:
Fit great under the 18" Pegs.
DO NOT FIT under my 17" Winter Titans. Require 5mm spacers at a minimum.
Look:
Well, you can see for yourself...HAWT
Performance:
As this is my DD, I'm not exactly stressing the limits of braking on a daily basis, but I have to say, the difference in modulation is outstanding over stock. The peddle feel just fills me with confidence. I've "Tested" a few simulated hard stops from 40-50mph, and they have zero fade coupled with a good eye pulling sensation. Obviously, long term performance I will reserve judgement on, but I'm suspecting, as I use them year round, I'll be "rebuilding" once a year to maintain good performance. (This kit DOESN'T have boots)
Price:
Even with potentially having to rebuild these once a year, this price is awesome for this whole kit. Well worth it as a DD brake upgrade.
Love em...
"Yarth" - 95 T5-R(m) - 18t,r-mani, 3" custom DP, EST 2.5 Cat back, IPD Stage III tune, MBC @ 17psi, RIP Kit, Sconeman Post Maf goodness, IPD plug wires, MSD ignition,IPD Short Ram intake, IPD Sways, Koni FSD's with Eibachs, 18" pegs, M56H with Quaife LSD and short shifter plate
#2 Geevs
Geevs
  • 1,819 posts
Posted 01 December 2009 - 05:07 AM
Hawt! What are you planning to run for winter wheels? Didn't you have 17x8" R reps? Those should clear the BBKs being 1" wider than the Titans.
#3 maciekb2002
maciekb2002
  • 1,094 posts
Posted 01 December 2009 - 05:08 AM
This is my kit. Worst part is that is they noisy like a bus sometimes, poor pad to caliper fit to much free play. Caliper could be a litter bigger but it stops great . Locked wheels at 90 MPH , that was emergency.
Total with new s60r rotors $300. That part I like
Build block,93 cams ,precision 5031E ,custom manifold, M56h ,custom 850r clutch, FMIC ,Full exhaust system, recaro seatd,custom 4 pistom alfa BBK , Sway bars and links , Bilstein suspension, Turbo Tuner
Dyno.
Runs like a champ , finally
PM me if you need any volvo parts
#4 volvoluvin
volvoluvin
  • 669 posts
Posted 01 December 2009 - 05:24 AM
I sold the Peg reps, kept the Titans that came with Yarth...I've got them shod with winters already to go...just waiting on the spacers from IPD...should be here by the weekend.
#5 POSTITSORGTFO
POSTITSORGTFO
    MILFSPEED
  • 30,269 posts
Posted 01 December 2009 - 06:28 AM
http://i155.photobucket.com/albums/s310/maciekb2002/volvo%20build/100_5342.jpg
I didnt sell you those :unsure: but if you want upgrade brakets let me know :D
you know I would of figured they would of fit under the titans :huh: hmm odd.
anyhow glad you like them and about time you installed them :lol: :lol: :lol:
Also here is a link to how to rebuild your calipers also .
http://www.circletrack.com/techarticles/ctrp_0612_brake_caliper_rebuild/index.html
#6 volvoluvin
volvoluvin
  • 669 posts
Posted 01 December 2009 - 06:29 AM
ya ya.
Well, they don't. Even with a 3mm adapter it's waaaay to close for comfort. And if you have proper inside wheel wieghts installed, 5mm spacers make it tight.
#7 Colbert
Colbert
  • 139 posts
Posted 01 December 2009 - 03:08 PM
I'm thinking about these caliper, with smaller disc like 305mm instead, as they don't use all the disc area and should fit behind Titan without spacers.
Does it mean there is no boots on the pistons ?
Signature Image Removed by Moderator - Broken Link, Malware Warning from Host
Volvo 360 GLT - 1986 - 231.000km
Volvo 855 T-5R - 1995 - 300.000km
#8 zebulon
zebulon
  • 4 posts
Posted 01 December 2009 - 03:19 PM
I have the same calipers front and rear kit. With pads provided with the calipers i have some awfull braking noises, i replace them by racing wilwood pads.Now really less noisy but still noisy when cold for the 3 or 4 stops, after it is ok.I fit some 17*7.5 BBS & i have 6 mm spacers to deal with the 330 mm discs.
Jean-Marc
855 R Green 1996 - M59 gearbox - 19T - HKS wastegate from Lancer Evo X
Rica tune (actually 24 PSI) - 330 mm Wilwood front & rear brakes - Volvo Sport 2.5 accesory exhaust - MSD coil - Magnecor Competition wires - Aluminium Intercooler - BBS 17wheels - 6 mm front spacers - 16 mm rear spacers - Ohlins front & rear
#9 cr854r
cr854r
  • 898 posts
Posted 01 December 2009 - 03:43 PM
so these wouldnt fit behind volans would they? im about to buy a set
Projekt R
-Megasquirt
, 18t, 3in turbo back, kw v2 coilovers, M56H, fmic, 16 point roll cage, corbeau seat/harness, gutted to hell, *solid bushings, *F/R sways, walbro 255, 450cc injectors, NA cams, willwood brakes, port/polished head, *rsi rods, *R mani, adjustable control arms, adjustable strut top mounts, adjustable sway bar links... etc etc
#10 volvoluvin
volvoluvin
  • 669 posts
Posted 01 December 2009 - 03:46 PM
Yes, no boots on the pistons.
Interesting, I'm not having any noise issues at all yet. Did the noise develop over time?
fitting over volans?
No clue, but my guess would be super tight over 330mm rotors
#11 zebulon
zebulon
  • 4 posts
Posted 01 December 2009 - 03:52 PM
Before mounting bbk Comet 17*7 where fitted on my car but when we first try to fit the bbk set, it would have need at least 10 mm or perpahps 15 mm spacers.It was due to the inside shape of the wheel, the bbs are straight from center to outside or nearly when comet are "curved" . i don't remember how is the inside of volans.
Noises appears after less than 500 km
I think it is due to the pads position, there is 1 mm of pads that did not cover the disc, so after few times it made a little lip on each pad.
I try to drill this lip on the first set of pad but i did not try to fit them since then.
Jean-Marc
#12 Captain Bondo
Captain Bondo
  • 639 posts
Posted 01 December 2009 - 04:48 PM
I wonder if there is a boot kit for those calipers, no dust boots with our sort of weather conditions is a major bummer IMO.
Looks pretty sweet though, nice to have some sort of upgrade with 18's.
#13 Colbert
Colbert
  • 139 posts
Posted 01 December 2009 - 04:59 PM
You'd better check with a pattern, but I really doubt with 330mm dics.
#14 lookforjoe
lookforjoe
  • 9,786 posts
Posted 01 December 2009 - 05:12 PM
They definitely are improvement over stock, and I know these are a relative bargain, but the reduced contact area would bug the crap out of me. Porsche setup fully covers surface area in the front & rear - with no noise at all - no protruding lip on the pads.
for comparison:
front
rear
#15 Mesoam
  • 19,734 posts
Posted 01 December 2009 - 07:06 PM
those calipers were not meant for that rotor, you have what maybe 20mm of non contact?!
#16 volvoluvin
volvoluvin
  • 669 posts
Posted 01 December 2009 - 07:07 PM
Sounds about right
#17 POSTITSORGTFO
POSTITSORGTFO
    MILFSPEED
  • 30,269 posts
Posted 01 December 2009 - 10:19 PM
wont work I already tired <_<
So ?
You can buy 2 peice rotors that will work for about 1k so if it matters that much go right ahead :lol:
or this also
As you can see here most of the space that would be normal rotor is now aluminum hat.
I am using the volvo rotors just due to cost you can get a aluminum hat one and have it cover the whole rotor but then your price would just a good bit.
#18 Mesoam
  • 19,734 posts
Posted 02 December 2009 - 12:05 AM
i'm no engineer but i'm pretty sure there is a reason they are designed to sweep the whole face and not leave a huge gap like that
#19 Colbert
Colbert
  • 139 posts
Posted 02 December 2009 - 12:47 AM
It just means a bit less pads area, a bit less effective than the Porsche BBK.
Wich is still way better than stock calipers. ;)
#20 Geevs
Geevs
  • 1,819 posts
Posted 02 December 2009 - 03:37 AM
What would be the optimal size for the Wilwoods if 330mm is too large and 305mm won't fit?
There is a rotor manufacturer in London, ON that makes blanks for various Volvos from 280mm to 320mmm (XC90) at a reasonable price. Perhaps if there is enough interest you might want to sell a kit containing the Wilwoods and matched-sized rotors that will fit 17" wheels without spacers - mainly for the advantage of running 17" i.e. smaller rotors for less unsprung(?) weight and cost, more compliant ride, winter wheels, etc. I would be interested if there was such a kit for a reasonable price.
