Key In Ignition = Doors Unlocking Themselves?
14 replies to this topic
#1 Casper850
Casper850
  • 125 posts
Posted 09 December 2009 - 01:39 PM
My wife's '98 S70 GLT has an issue with the door locks unlocking themselves if the key is in the ignition engine on or off. The locks operate fine if the key is not in the ignition.
Bad relay maybe?
(White)'95 854, 17" Giovanni Rims, Heavy-duty Billstien sport struts/shocks.
(Platinum) '98 S70 GLT, awaiting heart transplant...
#2 FCP Groton
FCP Groton
  • 1,838 posts
Posted 09 December 2009 - 06:53 PM
Does you car normally unlock the doors when the car is off? If so, it is probably a sensor or relay that is causing the issue.
Andrew Owendoff
#3 Casper850
Casper850
  • 125 posts
Posted 09 December 2009 - 07:05 PM
No, it will unlock the doors by itself only if the keys are in the ignition..on or off position. Once the keys are out of the ignition, it locks and unlocks as it should.
#4 Bah
Bah
  • 1,701 posts
Posted 09 December 2009 - 07:15 PM
I know in our american cars, when you put the key in the ignition, it would lock all the doors. If it did that before hand, i would think the relay to control that in the ignition switch went kabonkers.
1996 850 R - My Love, Suwanee
VS for life
#5 Casper850
Casper850
  • 125 posts
Posted 09 December 2009 - 07:29 PM
I'll see if I can figure out which relay is the issue and try to test swap it w/ one out of my daughters '95 854.
#6 BEJinFBK
BEJinFBK
  • 1,930 posts
Posted 09 December 2009 - 07:34 PM
It's all in the Owner's Manual:
http://new.volvocars...70_041.htm#pg43
- NOTE: To help prevent accidentally locking the keys in the car, the central locking system is designed to unlock the doors immediately if the key is left in the ignition switch and the car is locked using the lock button on the door. A sound from the lock will be audible at this time.
Please note that this function will not unlock the doors if the engine is running. -
I let my car warm up a lot in the winter and the only way to lock it while
it's running is to use a second key at the drivers door. Warm is Good!
#7 DonutsDemise
DonutsDemise
  • 3,447 posts
Posted 09 December 2009 - 07:36 PM
take your keys out of the ignition, problem solved. or disconnect the battery.
Jake
1998 Volvo S70 T5M 190k
#8 Casper850
Casper850
  • 125 posts
Posted 09 December 2009 - 07:38 PM
Thanks but that's not the issue I'm having. Simply put..the doors will not stay locked once the car is running (or if the keys are even in the ignition).
Ex: If we're driving down the road and try to lock the doors, they unlock themselves.
#9 BEJinFBK
BEJinFBK
  • 1,930 posts
Posted 09 December 2009 - 07:47 PM
Sorry - I misunderstood. I got nuthin'...But I'll keep thinkin' on it.
#10 Fudge_Brownie
Fudge_Brownie
    Hippie Exterminator
  • 9,771 posts
Posted 09 December 2009 - 07:50 PM
Because it is supposed to do this when the keys are in the ignition but the car is NOT running, there must be some system or relay that the car uses to determine this. As his mimics this attitude while the car is running, that sensor is probably bad. Can anyone suggest where he might look? Justin probably knows this one...
86 Kawasaki Gpz900R Ninja
#11 Быстров
Быстров
  • 523 posts
Posted 09 December 2009 - 10:55 PM
Bad relay maybe?
is it a volvo?
hmm if so think i see what u did there :)
sorry im just bitter, volvos failed me.
Romans 1:16
16) I am not ashamed of the gospel, because it is the power of God for the salvation of everyone who believes: first for the Jew, then for the Gentile.
#12 JordanW
JordanW
  • 415 posts
Posted 10 December 2009 - 04:20 AM
You could try swapping out the central locking relay and see what happens.
Do you have any kind of aftermarket alarm or remote start installed?
*-J-*
#13 mattk42589
mattk42589
  • 36 posts
Posted 10 December 2009 - 06:07 AM
maybe a bad ignition switch
#14 DonutsDemise
DonutsDemise
  • 3,447 posts
Posted 10 December 2009 - 09:17 AM
it might be that the locking unit thinks a door is open because a door is not closed properly or a switch is going bad. if a door is open with the keys in the ignition, the doors are supposed to automatically unlock. so that thing in the manual is part of the problem, but shouldn't be happening. check to see which courtesy lights are on when the door is closed if that is your problem. do the interior lights ever stay on?
Jake
#15 Casper850
Casper850
  • 125 posts
Posted 10 December 2009 - 02:03 PM
Doh!!!!!! I completely forgot about a problem she was having several months back with her rear pass. door light staying illuminated. I pulled the bulb as a temp solution (not really) but never got around to tracing the root of the problem. DonutsDemise (love that screen name BTW! ) I think you're onto something with the locking unit thinking a door is still open!
Looks like I have a homework assignment ahead of me lol.
