Guest Volvo_Noob420
Need Help. Is This C70 A Lpt Or Hpt ?
15 posts in this topic
Looking at buying a VOlvo C70. The dealer doesnt know if it is a LPT or HPT. Can somebody please help me identify which it is.
The Vin # is YV1NC63D93J036972
Thank u guys so much for helping. Hopefully, I will be a proud volvo owner in the near future.
0
Hmmm, I thought for C70, '63' on position 6th & 7th indicates HPT engine, and '56' on same position mean LPT.
Do I have that wrong?
0
Here is Volvo's listing of engine codes, for 1997 to 2006 (5 cylinder only).
Note that C70 started in 1998, and Volvo didn't differentiate the C70 codes until 2001.
HPT engines for C70
"53" in 1998-2002
"62" in 2003-2004
LPT engines for C70
"56" in 1997-2002
"63" in 2003-2004.
Confused yet?
OK, look at type "52" which is the 2004- R cars. Note that it is the B5254T3 in 2004, and then B5254T4 after that. What?
I've provided the codes by code type first, and then took the information off of Volvo's site to show the codes as they were shown by year. look at
http://apps.volvocars.us/ownersdocs/2001/2001_VIN-VIC/vic2001.html
where "2001' in the year, and you can substitute your year, using 1997, 1998, etc consistently for each of the "2001"'s and you can decode your car. Works from 1997 to 2006.
You need the body style to determine which car you have:
Volvo Engines
body style 4th digit
YV1K 960
YV1L 850/S70/V70
YV1V S40
YV1N C70
YV1R S60
YV1S V70
YV1T S80
5th digit
S 4 doors
T 4 doors AWD
H 4 doors AWD (S60R)
W 5 doors
V 5 doors AWD
J 5 doors AWD (V70R)
Z 5 doors AWD XC
6th and 7th digits determine engine type:
YV1xx50 B5234T4 1997 only 850 R 250 hp (where?)
YV1xx51 B5252S Canada only?
YV1LT52 B5234T6 1998 Only V70R HPT 236 hp/AWD
YV1LS52 B5234T3 1998 Only S-70 T5 HPT 236 hp
YV1RH52 B5254T4 2004- S60R 300 hp (KKK turbo)
YV1RJ52 B5254T4 2004- V70R 300 hp (KKK turbo)
YV1xx53 B5234T3 1999-2000 HPT 236 hp
YV1Rx53 B5234T3 2001-2004 HPT S60/V70 T5 247 hp
YV1Nx53 B5234T3 2001-2002 HPT C70 236 hp
YV1Rx54 B5244T5 2005/2006 HPT S60/V70 T5 256/257 hp (with KKK turbo)
YV1xx55 B5254FS 1997-1999 168 hp
YV1xx55 B5254S Denso ?
YV1Sx56 B5254T 1997-2000 LPT S70 190 HP
YV1Nx56 B5244T 2001-2002 C70 lpt 190 HP
YV1LS57 B5234T1 1997 only 850 T-5 222 hp
YV1LS58 B5234T5 1997 only 850 T-5R 240 hp
YV1xx58 B5244T3 2001-2003 LPT S60/V70/V70XC FWD or AWD 197 hp
YV1xx59 B5254T2 2003- 2.5T LPT S60/V70, S80, XC70/90 FWD and AWD 208 hp
YV1ST60 B5244T2 2000 only V70R HPT 261 hp (with TD04-19T turbo?)
YV1xx61 B5244S 2003- S60/V70 2.4 168 hp
YV1xx62 B5234T3 1999 only 247 hp (V70R wiht TD04-18T turbo?)
YV1Nx62 B5234T9 2003/2004 C70 HPT 246/242 hp
YV1Nx63 B5244T7 2003/2004 only C70 lpt 200/197 hp
YV1xx64 B5244S6 2003 S60/V70 FWD 168 hp 2004- S60/V70 FWD 165 hp
YV1xx65 B5244S2 ?
YV1xx68 B5254T3 2004- S40 T5 FWD/AWD 218 hp
1997
50 = B5234T4 20-Valve 5 cyl Turbo (250 hp "R")
55 = B5254S 20-valve 5 cyl (168 hp)
56 = B5254T 20-valve 5 cyl (190 hp GLT)
57 = B5234T1 20-valve 5 cyl Turbo (222 hp T5)
58 = B5234T5 20-valve 5 cyl Turbo (240 hp "R")
1998
52 = B5234T6 20-Valve 5 cyl Turbo (236 hp/AWD)
52 = B5234T3 20-Valve 5 cyl Turbo (236 hp)
56 = B5254T 20-valve 5 cyl (190 hp GLT, AWDN AWDA, AWXC)
1999
53 = B5234T3 20-valve 5-cylinder (236hp)
55 = B5254S 20-valve 5-cylinder (162hp)
56 = B5254T 20-valve 5-cylinder (190hp)
62 = B5234T3 20-valve 5-cylinder (247hp)
2000
53 = B5234T3 5-cylinder (236hp)
56 = B5244T 5-cylinder (190 hp)
60 = B5244T2 5-cylinder HPT R (261hp)
2001
53 = B5234T3 5-cylinder (247 hp) - V70 T5)
53 = B5234T3 5-cylinder (247 hp) - S60 T5)
53 = B5234T3 5-cylinder (236 hp) - C70 HT)
56 = B5244T 5-cylinder (190 hp) - C70 LT)
58 = B5244T3 5-cylinder (197 hp) - V70 2.4T, V70XC AWD)
58 = B5244T3 5-cylinder (197 hp) - S60 2.4T)
2002
53 = B5234T3 5-cylinder (236 hp) - C70 HT Coupe C70 HT CV)
56 = B5244T 5-cylinder (190 hp) - C70 LT CV)
58 = B5244T3 5-cylinder (197 hp) - V70 2.4T, V70 AWD, V70XC AWD)
58 = B5244T3 5-cylinder (197 hp) - S60 2.4T, S60 AWD)
2003
59 = B5254T2 5-cylinder (208 hp) - XC 90 AWD, S60/V70 AWD
61 = B5244S 5-cylinder (168 hp) - V70 2.4
61 = B5244S 5-cylinder (168 hp) - S60 2.4
62 = B5234T9 5-cylinder (246 hp) - C70 HT CV
63 = B5244T7 5-cylinder (200 hp) - C70 LT CV
64 = B5244S6 5-cylinder (168 hp) - V70 2.4
64 = B5244S6 5-cylinder (168 hp) - S60 2.4
2004
38 B5244S4 5-cylinder / Naturally Aspirated (168 hp) - S40 2.4i
52 B5254T3 5-cylinder / Turbo (300 hp) - S60/V70 R
53 B5234T3 5-cylinder (247 hp) - V70 T5
53 B5234T3 5-cylinder (247 hp) - S60 T5
59 B5254T2 5-cylinder / Turbo (208 hp) - S80 2.5T, S80 AWD S60/V70 FWD/AWD, XC70 AWD, XC90 FWD/AWD
61 B5244S 5-cylinder / Naturally Aspirated (168 hp) - S60/V70 2.4
62 B5234T9 5-cylinder / Turbo (242 hp) - C70 HT CV
63 B5244T7 5-cylinder / Turbo (197 hp) - C70 LT CV
64 B5244S6 5-cylinder / Naturally Aspirated (165 hp) - S60/V70 2.4
68 B5254T3 5-cylinder / Turbo (218 hp) - S40 T5
2005
38 = B5244S4 5-cyl./ 2.4 Ltr/149 in3 / Naturally Aspirated / 168 hp S40/V50 2.4i
39 = B5244S7 5-cyl./ 2.4 Ltr/149 in3 / Naturally Aspirated / 168 hp S40/V50 2.4i
52 = B5254T4 5-cyl./ 2.5 Ltr/154 in3 / Turbo / 300 hp S60/V70 R AWD
54 = B5244T5 5-cyl./ 2.4 Ltr/147 in3 / Turbo / 256 hp S60/V70 T5
59 = B5254T2 5-cyl./ 2.5 Ltr/154 in3 /Turbo / 208 hp S80/S60/V70/XC90 2.5T FWD/AWD, XC70 AWD
61 = B5244S 5-cyl./ 2.4 Ltr/149 in3 / Naturally Aspirated / 168 hp S60/V70 2.4
64 = B5244S6 5-cyl./ 2.4 Ltr/149 in3 / Naturally Aspirated / 165 hp S60/V70 2.4
68 = B5254T3 5-cyl./ 2.5 Ltr/154 in3 / Turbo / 218 hp S40/V50 T5 FWD/AWD
2006
38 B5244S4 5-cyl./ 2.4 Ltr/149 in3 / Naturally Aspirated / 168 hp S40/V50 2.4i FWD
39 B5244S7 5-cyl./ 2.4 Ltr/149 in3 / Naturally Aspirated / 168 hp S40/V50 2.4i FWD
52 B5254T4 5-cyl./ 2.5 Ltr/154 in3 / Turbo / 300 hp S60/V70 R AWD
54 B5244T5 5-cyl./ 2.4 Ltr/147 in3 / Turbo / 257hp S60 T5 FWD
59 B5254T2 5-cyl./ 2.5 Ltr/154 in3 / Turbo / 208 hp S80/S60/XC90 2.5T FWD/AWD, V70 2.5T FWD, XC70 AWD
61 B5244S 5-cyl./ 2.4 Ltr/149 in3 / Naturally Aspirated / 168 hp V70 2.4 FWD
64 B5244S6 5-cyl./ 2.4 Ltr/149 in3 / Naturally Aspirated / 165 hp V70 2.4 FWD
68 B5254T3 5-cyl./ 2.5 Ltr/154 in3 / Turbo / 218 hp S40/V50 T5 FWD/AWD
2
wasn't going to quote your whole message, good info. I was going to say the same thing except much less detail hahahaha
just 63 is 03-05 lpt, 56 is 97-02 lpt :P
i'd get it if it is the right color combo for you. HPT is just a turbo swap and tune away...easy...did a LPT to HPT swap in my 99 XC70 and loving 17psi to all 4 wheels! My hpt c70 got a bigger HPT 18t.
0
and CR
0
I am selling my C70, do I have this right?
  • 2002 Volvo C70 HPT 2.3L
  • Condition: Excellent
  • Miles: ~78,000 miles
  • Color E/I: Moondust ( Beige ) / Tan
  • VIN: YV1NC53D42J027296
It's in great shape, and I have an extended warranty for it that I can transfer to the new owner that is good till 3/17/2011 or 98,979 miles (which ever comes first). I have already used the warranty to fix the front suspension, and I am going to get the AC worked on now before I sell it. I am only selling the car because I am moving to San Francisco, and no one needs a car in SF. I really enjoyed cruising around Santa Monica, Hollywood, Mulholland Dr. and Malibu in this car.
If you are interested let me know.
twitter.com/jdavid
i guess the following Wikipedia articles may need some work
  • http://en.wikipedia.org/wiki/Volvo_Modular_engine
  • http://en.wikipedia.org/wiki/List_of_Volvo_engines
  • http://en.wikipedia.org/wiki/Volvo_C70
0
nothing wrong with lpt's lol
True, but the HPT has better power out of the box and can easily hit the 300 HP mark. Where as the LPT engine needs a little more help to hit that mark.
0
0
I need your help. I´m from Ecuador and I have a 2005 Volvo S40 2.4L A/T,the engine is a B5244S version the VIN #: YV1MS664952064447, according to the S40 models, the S40 2.4L A/T has 140 hp and the S40 2.4i have 170 Hp. I checked for more info and the engine B5244S is for the S60.
Do you know how many Hps do my S40 have? why does my car has the engine of the S60? According to the owners manual the s40 must be equipped with the engine B5244S4 or B5244S7!!
I would like to know if that engine is Ok for my car and how many hps has the engine
0
