How Big A Job?
Started by kinetic, Nov 28 2004 04:54 AM
13 replies to this topic
Posted 28 November 2004 - 04:54 AM
96 850
I have a creaking sound when I turn my wheel to the left- most noticably when making a U-turn. My Indie says it's the passenger side axle. I am curious how big a job it is to replace- I have replaced the wheel hubs, rotors and brakes in the past with the help of Bay 13. How big a job and can I do it using without a lift?
Thanks!
Thanks!
Posted 28 November 2004 - 03:37 PM
Kinetic,
I would say yes. Based purely off of my own experience with my indy replacing my front right axle. If you replaced wheels hubs...
however, he did it so quickly and easily it may have looked alot easier than it was. He did it, with a lift, in about 30-40 minutes. And he wasn't in a rush.
-Joe
-Joe
Sold my 95 850 in June of 05 at 140+k....now looking back to volvo as a potential future car.
Currently driving an 06 Civic SI
Posted 28 November 2004 - 04:34 PM
The job isn't that bad, use the post in the maintenance section for doing the bearing hub as a guide. Make sure your steering stop are lubricated well before blaming the axle.
http://www.volvospeed.com/Repair/FWDbearingHub.htm
Posted 29 November 2004 - 12:28 AM
i knocked that job off in 20 min with air tools, its really easy
scott sanders
1997 850 T5// RIP 05 V70R 6SPD
Posted 30 November 2004 - 06:12 PM
I second the comment on making sure your steering stops are well greased. I had a terrible creaking sound and thought the worst
until I applied $.05 worth of grease on the stops. Good as new
Chris
05 BMW 525
03 Acura MDX
94 Porsche 968 Cab
98 Volvo S70 T5 - Sold
05 BMW 525
03 Acura MDX
94 Porsche 968 Cab
Posted 30 November 2004 - 10:01 PM
Once the axel is out of the hub, it just pops out of the transmission, correct? Or is there some special tool needed to hold clips open or something...
Posted 01 December 2004 - 12:27 AM
Once you have the axle out of the hub, the end that is in the tranny will come out by carefully pushing it out with a large flat head screwdriver or pry bar. Be careful while doing this, but with a little prying the axle will pull out of place. Pry in between the CV joint and tranny. Mine pulled out with little effort when I replaced my CV Boots. Good luck.
1994 850 Turbo
Posted 01 December 2004 - 12:45 AM
Second question, thanks for all the help. If the axle is making the trademark "popping" noise that indicates a problem (hence why I'm asking), is it necessary to replace the entire thing? I know the outboard CV boot is bad, would replacing it and regreasing the joint solve the problem? I think the axle has 84k on it right now. There is a significant difference in price from a brand new axle, a rebuilt one, and a CV boot kit.
Posted 01 December 2004 - 12:50 AM
If the Axle is making noise, repacking the grease with a new boot will not fix it. I've not seen the inner or outer CV shaft parts offered seperately.
#10 Guest_Guest_whilst_*_*
Posted 01 December 2004 - 04:20 AM
Try: "raxles.com". Out of Florida.
NEW joints available,complete w/boot,clips,synthetic grease.
Excellent price and service.
HTH.
HTH.
Posted 04 December 2004 - 05:33 PM
I finally got around to looking at member posts regarding replacing the axle. Thanks for all the hints. It sounds like the axle can be pulled out when the hub is off correct? secondly, where are the "stops" that are mentioned here? I might try the grease application first.
Thanks again
Thanks again
Posted 05 December 2004 - 01:04 AM
Thanks for the link- do I simply apply to the outsides?
#14
Posted 05 December 2004 - 01:16 AM
correct, just turn the wheel out and grease the two plastic pieces: one is
below the brake caliper....
1995 850 glt rattling down the road at 157K
99 V70XC 120K
99 V70XC 120K
