Na Cams
Started by Mogatu'r, Jan 29 2010 06:39 PM
10 replies to this topic
Posted 29 January 2010 - 06:39 PM
Anyone out there can provide the different p/n and duration of the NA cams?
TIA!
TIA!
brinquedo 00R-M 309hp/385tq / '97-855R 26k miles on Volvo rebuild, Weitec kit / daily... 98 v70 t5 wifey...E36 m3 cooling system overhauled:check:
Posted 29 January 2010 - 07:10 PM
No P/Ns, but these threads might be a good start in the right direction for you
http://volvospeed.co...-with-23l-block
http://volvospeed.co...on-my-850-t5-r/
Posted 29 January 2010 - 07:21 PM
Thanks, already checked those. '93 seem to be the one off with higher duration, just want to know the exact #.
Posted 30 January 2010 - 04:02 AM
I dont know much about cams
, but was curious if there would be advantage to making adjustable gear like in the older models??
Contact me for turbos, turbo parts and rebuild kits
Posted 30 January 2010 - 08:43 AM
me 2
00 S70 GLT, 98 S70 T5M, 91 760 TURBO, 98 S70 N/A, 96 850R
PART OUT: silver 98 s70 t5a black interior
Posted 12 February 2010 - 08:19 PM
Just wanted to update this thread with some useful info. The '93 N/A Intake Cams are very similar to the, 94+. However the Exh Cam is bigger and has a noticeable more aggressive lobe.
Cams were installed and adjusted by Aaron from Racelab Fabrications, 4* on the Int and Exh, right at 2,3k RPM's car picks up a lot faster than before, I have not had a chance to put my tuned ECU in. But at partial throtle there's def a difference.
Posted 12 February 2010 - 08:54 PM
How much has the top end changed?
Posted 12 February 2010 - 09:08 PM
93 and early 94
late 94-97
here is an older post
http://volvospeed.co...__1#entry257926
and some more info
http://volvospeed.co...1
late 94-97
and some more info
-Kevin-
04' Subaru WRX Wagon
:( 96' White 854, 19t, Quaife M56H, Turbo tuner :(
Posted 15 February 2010 - 02:22 AM
So we have discussed the exhaust profiles differences but what is the difference between the intake cams between 93 and late 94+, they seem to have different part #'s?
What would the best combination be if mixed and matched between the two NA/s and my T5 stockers?
Also, I recall someone said that the timing gears are the same for turbo and NA but I believe they have different part #'s... NA 3531522 Turbo 3531523.
Are they the same part with different part #'s or some insignificant difference?
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted 15 February 2010 - 03:07 AM
No reason to worry about the gears. I'd use the ones intended for your year motor (the ones now on the car), that's what's important.
