TheSwedeSpotRVA
Evap Code P0440 On 1995 Volvo T-5R
I have a 95 t-5r that persistently throws the 0440 egr code. This car is running an ecu from a 1996 R car (also upsolute tuned) with otherwise great results. First of all is it the difference in year between them that is causing this code? Can I remove/modify the EGR system, or perhaps tune the ecu to delete the EGR so that I don't get the code? Second, if the above is NOT the case, what should be my next step in getting this light to stop coming on. I have replaced most of the egr line, straight and elbow connectors, and the pressure sensor/vacuum controller solenoid that rests under the radiator shroud. Next I suppose I'll replace the EGR temperature sensor, EGR Valve (If I can FIND them) and the charcoal canister. I did see that there are two parts the 96 850 uses in its EGR system that are not found on the 95 model: an EGR air pump valve and an evap purge valve. Can I add these two components and cure the code? What would be my best option at this point? Just keep clearing the code over and over with my handy pocket 0BDII reader? Grrrr
Oh yeah, and on the flip side of adding components from the 96 year model EGR system if necessary, are there also ones which should be removed from the 95 system? thanks!!! B)
JordanW    20
P0440 is an EVAP code. NOT EGR. They are 2 completely different systems. Frequently evap codes can come from broken, rotted, and torn rubber connectors on the plastic lines that run from the EVAP purge valve, to the charcoal canister, the connector by the front sub-frame to chassis on the right side, to the roll over valve, and sometimes on the vent on the tank itself. Also common are pluged and sticking EVAP purge valves, located on the fan shroud.
You have 3 different systems you are talking about; the EVAP - Evaporative emissions - unburnt "gas" fumes from the tank; EGR - Exhaust gas recirculation, takes spent exhaust gases from the manifold and meters it and induces it into the intake manifold; SAS - Secondary air system - Uses a air pump to inject ambient air into the exhaust usually during cold starts to improve cat. efficency.
If you are getting P0440, I would start with the EVAP purge valve, clean it out, make sure it's connected, then check your vacuum lines to and from it.
Well I worked on both systems I guess, mistakenly thinking they were related. The evap purge valve is what I have replaced then...tried two different units. I also switched out the rubber connectors and yellow and white plastic lines running together from the evap purge valve up to the two nipples on that area near the intake where the constant idle thing is located (under the black plastic cover). I also replaced the lines and elbow connectors to the charcoal canister. So I guess my last resort is the charcoal canister? Any thoughts on whether the code could be from the 96 computer in a 95 car? If so is there any way to modify it so the code will go away? Thanks
Ihatespeedbumps    1,084
If you have swapped Evap valves, it might be time to look for a leak. Charcoal canisters typically only fail when you top of the fuel tank continually and saturate the canister, which can cause the engine to suck raw fuel. If your not a topper upper... look past the canister.
I suspect one of the hoses on top of the fuel tank has split, and is causing an evap leak. The best way to check for a leak would be smoke testing or using some sort of metered air and watching for a pressure drop. If you don't have access to that equipment you can get under the car and inspect the fuel tank for stains, which would indicate a fuel leak. Alternately, you can remove the fuel pump cover and use a flashlight and mirror to look for split hoses.
I don't think there are any differences between 95 and 96 evap systems, but I'm not 100% certain either. Did the DTC occur right after installing the 96 ECU?
I will edit the title of your thread so you might get more responses.
cheapwagon    357
Replace the gas cap before proceeding. Most common fix.
took care of my P0440
I've replaced the gas cap with two different onee, made sure I clicked it 6-7 times, checked the filler neck, etc. So next I will try to look at the gas tank myself as was suggested above and look for wet spots....grrrrrr CEL's
JordanW    20
Here is some insight for you on your P0440 Hope it helps. The below was found at: http://www.volvoclub.org.uk/volvo_workshop-850techdocs.shtml
Code 3-1-5 (EVAP System)
1) Check for other codes. If Code 5-4-1 is also present,
check that code first. If Code 5-4-1 is not present, go to next step.
2) Start and run engine at idle. Remove vacuum hose between
EVAP valve and intake manifold. If vacuum is present in hose, go to
next step. If vacuum is not present in hose, check for obstruction.
Also check hose connection to intake manifold.
3) Start and run engine at idle. Connect hose between EVAP
valve and intake manifold to EVAP valve. Remove hose between EVAP
valve and canister from EVAP valve. If there is no vacuum in EVAP
valve when valve is not activated, go to next step. If there is
vacuum, retest using new EVAP valve.
4) Start and run engine at idle. Disconnect hose between EVAP
valve and canister at EVAP valve. Check if there is vacuum in EVAP
valve when valve is activated. If there is vacuum, go to next step. If
there is no vacuum, retest using new EVAP valve.
5) Start and run engine at idle. Connect vacuum hose between
EVAP valve and canister to EVAP valve. Remove vacuum hose between EVAP
valve and canister from canister. Check if there is vacuum in hose
when EVAP valve is activated. If there is vacuum, check if all
canister inlets and outlets are okay. Repair as necessary. If inlets
and outlets are okay, fault is intermittent. Go to next step. If no
vacuum is present, check for obstruction in hose between EVAP valve
and canister.
6) Check hose between EVAP valve and intake manifold, and
between EVAP valve and canister for an obstruction. Check canister
connections to ensure they are not clogged. Check EVAP valve for dirt
or deposits. Repair as necessary. If no faults can be found, test
system using new EVAP valve.
Code 5-4-1 (EVAP Signal)
1) Check status message on Volvo Scan Tool (998-8686). If
fault is permanent and signal is too high, go to step 2). If fault is
PERMANENT, SIGNAL TOO LOW, go to step 3). If fault is INTERMITTENT,
SIGNAL TOO HIGH, go to step 7). If fault is INTERMITTENT, SIGNAL TOO
LOW, go to step 8).
2) Turn ignition off. Disconnect EVAP valve. Connect ohmmeter
between EVAP valve connector terminals No. 1 and 2. If ohmmeter reads
about 26 ohms, check wiring between EVAP valve connector terminal No.
2 and ECM terminal A39 for a short circuit to voltage. If ohmmeter
does not read 26 ohms, retest using new EVAP valve.
3) Turn ignition off. Disconnect EVAP valve. Turn ignition
on. Connect voltmeter between EVAP valve connector, terminal No. 1,
and ground. If voltmeter reads battery voltage, go to next step. If
voltmeter does not read battery voltage, check wiring between EVAP
valve connector terminal No. 1 and main relay connector terminal No. 3
for an open circuit.
4) Turn ignition off. Wait about 2 seconds. Disconnect EVAP
valve. Connect ohmmeter between EVAP valve connector terminal No. 2
and ground. If ohmmeter reads 25-40 k/ohms, go to next step. If
ohmmeter reads infinite resistance, go to step 6). If ohmmeter reads
about zero ohms, check wiring between EVAP valve connector terminal
No. 2 and ECM terminal A39 for a short circuit to ground.
5) Turn ignition off. Disconnect EVAP valve connector.
Connect ohmmeter between EVAP valve connector terminals No. 1 and 2.
If ohmmeter reads about 26 ohms, code is caused by poor contact in
EVAP and/or ECM connector. Repair as necessary. If ohmmeter does not
read about 26 ohms, retest using new EVAP valve.
6) Turn ignition off. Disconnect EVAP valve connector.
Disconnect ECM. Ensure ECM connector terminals are clean and make good
terminal contact. Repair as necessary. Connect ohmmeter between EVAP
valve connector terminal No. 2 and ground. If ohmmeter reads 25-40
k/ohms, code is caused by poor contact at ECM connector. If ohmmeter
does not read 25-40 k/ohms, check wiring between EVAP valve connector
terminal No. 2 and ECM terminal A39 for an open circuit.
7) If fault is intermittent and signal is too high, check
wiring between EVAP valve connector terminal No. 2 and ECM terminal
A39 for an intermittent short circuit to voltage. Repair as necessary.
8) If fault is intermittent and signal is too low, check EVAP
valve and ECM connector for loose connection or contact resistance.
Check wiring between EVAP valve connector terminal No. 1 and main
relay connector terminal No. 3 for an intermittent open circuit. Also
check wiring between EVAP valve connector terminal No. 2 and ECM
terminal A39 for an intermittent open circuit or short circuit to
ground.
