Installed Brake Pads
7 replies to this topic
#1 gray1g
gray1g
  • 101 posts
Posted 01 December 2004 - 01:58 AM
Just like it states I installed new rear calipers/rotors/and pads on my 95 850 Turbo Wagon. My question is do you have to use the clips that look like a cross? The ones that go around the pins and over the pads.
I didn't put them on so what could happen??? Thanks
1995 850 Turbo Wagon
K&N drop in
Speed Tuning chip 17psi
Stage -.5 almost stage 0
Sold
#2 Alston850
Alston850
  • 60 posts
Posted 01 December 2004 - 02:10 AM
Yes, you should put them on.
It should only take you a few minutes per wheel. Push the bottom pin out, hook the clip under the top pin, hold down the clip and work the bottom pin back through on top of the clip, make sure both pins are seated and your done.
Tim
1995 850 Turbo Sedan/
TME Springs/IPD Sway Bars/HD Bilsteins/Euro Sport Strut Tower Brace
Power Slot Rotors/IPD SS Brake Lines
AutoMeter Boost Gauge
Centerline Alloy Rims/Goodyear Eagle F1 GS D3 235/40/17
IPD Skid Plate
1997 S70 TR/Stock
1981 240 DL Sedan /Stock
#3 jda2000
jda2000
  • 1,027 posts
Posted 01 December 2004 - 03:27 AM
its called the antiratlle spring, and you need to put them back, or.. huh.gif
you'll get fast and uneven pad wear and mostly of all, you'll get noises from the brakes
John, Sarasota, FL
'01 V70 T5, '07 S60 2.5T
#4 starfish
starfish
  • 749 posts
Posted 02 December 2004 - 05:26 AM
Did you install the stainless steel brake pad shims?
<insert witty comment here>
#5 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 02 December 2004 - 05:52 AM
Anyone have a good pic of what pins these are? I'm having a hard time picturing them in my head...
#6 gray1g
gray1g
  • 101 posts
Posted 02 December 2004 - 01:22 PM
QUOTE(starfish @ Dec 2 2004, 01:26 AM)
Yes. The one side was sticky which attached to the back of the pad and the other side was a black "non slip" material. They are on nice but still wonder why the clips must go on. They seem to be in there nice and tight as they are.
K&N drop in
Sold
#7 Guest_Guest_*
Guest_Guest_*
Posted 07 December 2004 - 03:11 AM
You have to put them on because WE SAY SO!!!
Actually, if you leave enough parts off, your car will get lighter and get better mileage.
OR, you may smash into something.
#8 DEWFPO
DEWFPO
  • 539 posts
Posted 07 December 2004 - 08:10 PM
The shim changes the angle of attack between the pad and the disc. Without the shim, the brakes may/will squeal.
DEWFPO
