Well, I wasn't quite sure what to expect today. I was working on my car all the way up to tech inspection while waiting in line!
While it wasn't what I would have liked, it's still certainly respectable. Here's the slip...
R/T: .111
60': 2.149
330': 5.927
1/8 mile: 9.046
MPH: 78.96
1000': 11.751
1/4 mile: 14.040
MPH: 98.54
Car setup:
1994 850 Turbo wagon, automagic, 200k+ miles
TheLostArtOf ECU tune, 3" turbo back exhaust, Buggered frankenturbo, N/A cams, white (34lb) injectors
AEM TrueBoost EBC @ 16.3psi peak, 14.5-15psi stable
91 octane, 215/45/16 Hankook Ventus RS2
Removed jack, spare, and 3rd row seat.
I had actually removed the EBC yesterday, and put the stock solenoid back in...turns out the wiring circuit to the solenoid is dead I guess. I first tried my AC Delco unit which is about 2 months old, and I had no boost control at all (same as unplugging the actuator completely). Then I tried the stock BCS...same thing. So I had to re-install the EBC (thank goodness I brought it with me) while I was in line for tech. No time to dial in boost settings or even let the car adjust.
Had I been able to dial my boost in and run race gas, the numbers would have probably been a little better. But still, not bad, considering ~15psi and 91 octane.
No more track runs for the 850...time to get the 244 together and go for 12's.
Edited by L8 APEKS, 01 May 2010 - 08:26 AM.
