Fuse #15 is your verdict.
Glove box door being open makes me think glovebox light has a short. Go check it out. I'm assuming if you press in the black switch for the light, the dinging goes off right?
It's possible on the sunvisors..i'm gonna have to tackle that myself after the sh*t i'm going through with fuse 15 =p
Fuse 15 controls wayyyyy too much...it does diagnostic controller too
Does Door lock knowledge (if its blown, it doesn't know the door is closed)
Its supposed to do the radio, but, my radio works with it out lmfao...
The splash lights in the door when you open it(check those out)
Does all the overhead dome lighting as well.
This is what i ended up doing..taking out fuse 17 or 18 or w/e for the bing bong, and #15 since it was already blown.
Hopefully it's just the sunvisor in your case and hopefully the screws aren't cross threaded cause some a$$kid who did you headliner can't use power tools for jack =p
But anyways..give #15 a look over. my money is on its blown. And you'll put another one in and it'll blow right away again
Then the fun begins.
and because it doesn't know the drivers door is closed, it thinks it is opened. Therefore you get bing bing bing =p
