Clutch Bleeding?
Posted 25 March 2010 - 07:03 PM
1994 Volvo 850 Turbo Manual
ARD Green Tune | FMIC | OBX Turbo Back | Angled 16T | TurboSmart BOV
Posted 25 March 2010 - 07:05 PM
Short answer: yes, and they are a royal pain in the ass to bleed.
Posted 25 March 2010 - 07:10 PM
Posted 26 March 2010 - 01:19 AM
I bleed these by filling an oil can with brake fluid and I attach a hose to the slave. Suck some fluid out of the master cylinder and keep the cap off. Open the bleed screw and attach the hose and start pumping. You will see the master cylinder fill with fluid. Repeat this process a couple of times and the clutch hydraulics will be bleed correctly the first time
Posted 26 March 2010 - 04:10 AM
Basically when the car is off, its easy to shift, but when the car is moving (when I push it hard), it gets hard to shift threw gears. Similarly, when I try to downshift, its hard to get from 4 to 3 or 3 to 2...should I try changing the tranny oil? or is this usually a clutch related problem?
Posted 02 April 2010 - 11:53 PM
'98 s70 T5 SE 260km Silver Auto
$3000
Posted 03 April 2010 - 01:51 AM
when there's too much air in the system the clutch pedal does not spring back well. FYI best way to bleed it is using gravity, then finish with pumping up the slave and bleeding repeatedly until remaining air is out.The clutch pedal feels fine, its just hard to downshift sometimes or upshift when the car is under high boost...someone told me its cuz my clutch might be finished or the throwout bearing...I was just hoping maybe there was air in the system and the clutch wasnt completely disengaging.
Edited by sconeman, 03 April 2010 - 01:51 AM.
----PERFORMANCE VOLVO PARTS----
Posted 03 April 2010 - 06:03 AM
A very light pedal feel would indicate air in the system.
Edited by TyConn_S70, 03 April 2010 - 06:04 AM.
1998 V70 T5 M - FOR SALE, PM ME!
1994 854M Silver on Black
1998 Black on Black S70T51995 855 N/A @174K: Lightning strike, running on 4 cylinders, mixing fluids, holes in the gas tank, 3 different rims, exhaust leak. DD UNTIL 200K.... Killed By Faulty1998 S70 GLT...RIP at 320K
1990 245 DL M47
Posted 03 April 2010 - 08:59 AM
Alex
2013 C30 T5 R-Design - Rebel Blue - Polestar Tuned
Old/Parting: '98 V70R AWD FWD - M56L - 19T - TT - RICA - 17" Team Dynamics Motorsport - Pro Race 1.2 - 18" Pegs - CJ Porsche 993TT BBK - CarPc - Parts For Sale - Click Me!
Posted 03 April 2010 - 12:11 PM
I should clarify. I have a dedicated oil can that only houses brake fluid.
Posted 03 April 2010 - 03:07 PM
The easiest way to bleed for me is to use a pressure bleeder on the top in conjunction with the normal foot action bleed.
This is the method that I have used in the past and it works very well. It can be a little tricky to cleanly capture the fluid since you can't really see the bleeder valve while you're opening and closing it in time with the pedal action. Its hard not to knock it off sometimes.
Portsmouth, NH
#14
Posted 12 May 2012 - 12:29 PM
'96 850R wagon, white & black, 5 speed swap, Koni FDS/Eiback Pro Kit, ARD manual tune, IPD RIP kit, MSD ignition
