Stage Iii
#41
Posted 14 June 2010 - 12:58 PM
#42
Posted 14 June 2010 - 03:42 PM
Mesoam, on 07 May 2010 - 12:48 PM, said:
http://i69.photobuck...em/DSC02304.jpg
that is OG.
i was so drunk last night, i thought the toothpaste was astronaut food.
#43
Posted 16 July 2010 - 05:30 AM
Mesoam, on 14 June 2010 - 12:58 PM, said:
Can't really make up my mind about it, probably gonna order iPD's eggcrate one with chrome surround just to change it up a little
Anyways, some more progress.
Re-did the breather... twice. I managed to not clamp the elbow properly to the crankcase vent the first time, resulting in a huge oily mess. So I bought a 1" ID 90 degree elbow from Rona and used silicone couplers to create a snugger, freer-breathing fit.
Put on iPD's upper poly mount, replaced the ugly expansion tank, flushed the cooling system and replaced it with 25% Pentacin, 10% Redline Water Wetter, and 65% deionized water.
Transmission mount replaced with iPD unit. Also added a valve for easier catch can draining.
I also adjusted the wastegate and put in TME's Euro manual Stage III tune. 15psi peak, no more until I finally finish the meth kit install.
#44
Posted 16 July 2010 - 12:29 PM
1 of 1 - '97 427 854R - 110k
#45
Posted 16 July 2010 - 03:03 PM
NEW: 04 S60 2.5T AWD
OLD: 98 S70 T5M
| TME | IPD | ARD | Viva | Snabb |
#46
Posted 20 July 2010 - 06:10 AM
You are doing a great job of the car - Looks absolutely fantastic! Hope we can hook up for a show and shine sometime soon...
"Yarth" - 95 T5-R(m) - 18t,r-mani, 3" custom DP, EST 2.5 Cat back, IPD Stage III tune, MBC @ 17psi, RIP Kit, Sconeman Post Maf goodness, IPD plug wires, MSD ignition,IPD Short Ram intake, IPD Sways, Koni FSD's with Eibachs, 18" pegs, M56H with Quaife LSD and short shifter plate
#47
Posted 20 July 2010 - 02:45 PM
#48
Posted 21 July 2010 - 01:51 AM
#49
Posted 21 July 2010 - 02:38 AM
2007 Electric Silver S60R-------105.5k
#50
Posted 21 July 2010 - 03:25 PM
project_850, on 21 July 2010 - 01:51 AM, said:
Probably not, but details?
#51
Posted 21 July 2010 - 04:21 PM
Ya, I'll be at Cates this year for sure...should be fun
#52
Posted 21 July 2010 - 04:35 PM
IPD ECU - IPD Intercooler - AEM UEGO - MSD - Kingsborne - 3" Turbo-back exhaust - Apexcone - ABM Projectors - Koni struts
Bilstein shocks - EST springs - IPD rear sway bar - BMW endlinks - EST Strut Brace - Autometer Boost
http://www.cardomain.com/ride/2548811
#53
Posted 21 July 2010 - 04:47 PM
Her name is Violet, She's my Wagon.
#54
Posted 21 July 2010 - 06:41 PM
13.7 @ 99 Automagic
13.8 @ 104 Manual
1995 855M - Quaife, 18T, ARD Blue, Meth, 3" catless, FMIC, N/A(cams & TB), Scone, H&R, Bilstein
#55
Posted 21 July 2010 - 07:12 PM
#56
Posted 22 August 2010 - 11:30 PM
New intercooler, prior to deleting the condenser/compressor and running a 50" 6-rib serpentine belt. Also swapped the grille to the cube-type one, still undecided
Possible fun route that I'll be taking. Currently working on another polished intake manifold and tapping in the N20 jets..
On an unrelated note, also got a new go-fast(ish) toy:
Yamaha Raptor 350R. 5-speed manual w/ Reverse. Still a n00b at it but damn it's fun
#57
Posted 22 August 2010 - 11:42 PM
95 850 GLT | Tropic Green Metallic | 219k | ARD Tune | M56H | E-Code Conversion | Full LED interior
2W131L - USAF
#58
Posted 23 August 2010 - 01:02 AM
#59
Posted 23 August 2010 - 07:28 AM
#60
Posted 23 August 2010 - 12:11 PM
http://www.motosport.com/ has good deals
