My 850 Sounds Like A Tractor
6 replies to this topic
#1 kinetic
kinetic
  • 228 posts
Posted 05 December 2004 - 11:49 PM
96 850
This is a continuing problem regarding a sound my 850 makes on acceleration at any speed. The car sounds like a tractor, backhoe, grader etc... I have had the muffler checked it's fine, no CEL light, TB and IAC have been cleaned. Thel plugs, and MAF have been replaced. I am at a loss with the solution to this problem. Any ideas would be helpful.
#2 Guest_mikeklett@pmt.org_*
Posted 06 December 2004 - 03:26 AM
QUOTE(kinetic @ Dec 5 2004, 11:49 PM)
96 850
i would suspect a baffle is loose in the muffler.
#3 kinetic
kinetic
  • 228 posts
Posted 06 December 2004 - 03:42 AM
hmmm interesting-haven't heard that explaination yet. Given your explaination, would the sound be at or forward of the gear shift? The sound I hear eminates from just under the console where the the tranny meets at the engine compartment.
#4 kenk
kenk
  • 159 posts
Posted 06 December 2004 - 04:32 AM
check the flex joint, could be the metal piece has come loose, maybe manifold seals?
1996 volvo 850 5speed ~180k
1992 saab 9ks 5 speed ~205k
#5 Flyby
Flyby
  • 1,056 posts
Posted 06 December 2004 - 04:28 PM
If this is an exhaust sound, and not a mechanical sound, no big deal. I know you had the muffler checked, but if the sound is coming from under your console, you need to have the whole exhaust checked. Get it up on a lift and look for black spots on your exhaust. Another way my buddy found out he had a leak was feeling around on the floor. When he found a hotspot, he knew there was a hole on the non-visible side of the exhaust.
It really sounds like you just have a leak in your exhaust, do you remember bottoming out anywhere? Could have knocked your exhaust.
anyway, just my $.02
Nat
#6 kinetic
kinetic
  • 228 posts
Posted 09 December 2004 - 02:53 AM
I dont'recall any bottoming out-I did notice the gruff engine sound after my Indie replaced the bottom rear engine mount- could he have dislodged the exhaust components from the engine?
#7 96DTM850
96DTM850
  • 671 posts
Posted 10 December 2004 - 08:44 AM
rod knock??? spun a bearing??? sad.gif blink.gif wink.gif ph34r.gif that'll be all bad.
CLICK HERE-->NorCal Volvos <--CLICK HERE
www.Turbobricks.com
96 Volvo 850 BTCC replica...R.I.P Peter Brock 05
91 Toyota Supra Turbo BPU SOLD R.I.P.
91 Mitsu Galant VR4 BPU+ SOLD
