TFIVEM, on 06 April 2010 - 10:35 PM, said:
i think its been down a few times, but it never gets tagged. plenty of people have done LED swaps in there x70's. T5Power should know, he did a couple different set ups in s70 cluster, including the info screens.
i saw my name in the sky somewhere...
http://i7.photobucke...01/DSC00564.jpg
INFO CLUSTER, MILEAGE CLUSTER, WARNING LIGHTS and turn signals are type 74 bulbs, which cross over in the LED world as
T5 LED's (how fitting
these are also used for turn signals, and all bulbs to the left and right of the info cluster. i have replaced all of these as well.
20x for all warning lights to the left and right of info cluster (although not all of these are used)
3x for mileage and info cluster
2x for turn signal indicators
website: http://autolumination.com/74.htm
scroll down and buy these
they look like this, new is on the right(base color depending), old is on the left, with the base.
GAUGES are originally type 194 bulbs, which are
T10 LED's
4x for main gauge lighting
website: http://autolumination.com/194.htm
scroll down and buy these, these are great:
which look like this, base color and # of LED's depending
RADIO bulbs are originally "neo wedge"
T3 bulbs and are known as the same thing i believe for LED'S. in order to get these into the radio you have to dig out a little extra in the diffuser for the LED to fit flush.
5x for these led's, but i recommend buying extras. you may possibly break these, they're delicate
scroll down and buy these (T3)
SWITCHES use the
T3 & T4 LED's with the exception of the info switch, rheostat, heated seat switches and headlight switch, which use T3 but info switch requires fenagling to get in there. not 100% positive on rheostat though. i'm gong from memory so if anyone knows, that would be great
6x for the T4's
5x for T3's
scroll down and use the T3/T4 LED's
CLIMATE CONTROL i have not figured out the best LED's to use for the climate control yet. i jury rigged the T5 led's in there and they look pretty good.
**edit** update: apparently the LED's that fit are NEO4-X, from this website:
http://www.superbrig...=/specs/NEO.htm
this may also be the T4 type led's, but the climate control bulb shafts are extended.
results:
pictures make it look like there are hot spots, but there are none, and these are bright.
here's white in the stock cluster, looks ehhhh:
Amber:
there are plenty more pictures, just ask.
any other questions PM me
somebody please pin this or something.
Edited by T5Power, 03 September 2010 - 02:37 PM.
